Introduction: Wall Mount for Gaming
I made a nice mount for all of my gaming gear, like my headphones and controllers with a little shelf at the bottom for whatever you need. It can work with any gaming system, but it works best for Nintendo Switch, as it can hold joy-cons the best. I hope you like it! It can be scaled up or down depending on your needs.
Here's what you need:
A small piece of wood
A small board of wood
Something to cut the wood with (I used a bandsaw)
Clamps
Wood Glue
Step 1: Cut Out the Pieces
First, you need to cut out the pieces. The pieces you need are:
2x Small right triangles, with side lengths as big as your small squares
2x Small squares
1x Large square, side lengths as big as your plank's width
2x Slightly larger right triangles
Step 2: Glue the First Pieces
Glue together a small triangle and a small square as the picture shows. Do this for both small triangles and squares, then, take the large triangle and glue them on the bottom of the large square in a similar manner, but space the to the outside as the picture shows. Then glue the large and small squares to the plank... You guessed it! As the picture shows
Step 3: Clamp the Extra Bits
Take the extra small squares and clamp them on top of the other small square like in the picture.
Step 4: Glue the Joycons
Using some super glue, take the joy-con grips and glue them a little bit under the smaller hooks, make sure to test fit them and make sure you can get the joy-cons on and off easily
Step 5: Hang Everything On
Hang everything on as you need it.
Step 6: Good Luck and Happy Gaming!
Hope you find this helpful, Good luck gaming!
