Introduction: Wallhooky Setup
Step 1: Thing Needed
• a string • a ring • a small eye hook • a large hook
Step 2: Tools Needed
• a drill • two drill bits a little smaller then the screw part of the hooks
Step 3: Tying the String
The first thing you will do is to get the string and tie one end to the small eye hook do not tie this tight this knot will be adjusted later. Then you tie the other end to the ring, tie this end tight cause this will be the final knot at this end.
Step 4: Drilling Holes
You need to pre-drill both holes. You will drill the bigger hole for the large hook about 4-5 feet from the ground. The smaller hole you will drill above the large hook and around 4 feet from the wall.
Step 5: Attaching Hooks
Screw in both of the hooks. Then adjust the string at the small hook to the point at which there is very little slack in the string when put on the large hook and there is just the right amount of slack where the ring will come of the hook easy.
Step 6: Play Game
The goal is to get the ring on the large hook by swinging it from like 7 feet away
