Introduction: Walter the Sonar Bot
We will program Walter's Sonar
Step 1:
This a video tutorial following the instructable steps.
Step 2:
We will modify the Walter microbot code so we can have a working sonar.
Step 3:
Open the inputs tab and select On Button Press command which I have highlighted.
Step 4:
We will need 2 of these commands, make sure to change one of the buttons to B and leave the other on A.
Step 5:
Open the variables tab and click on make a variable
Step 6:
When you click on make a variable it will ask you to name it to make things simple just name it Button and then press ok, then you should see 3 commands appear.
Step 7:
Drag the Set Button command to On Button command like I showed.
Step 8:
Open the logic tab and grab the command that I highlighted.
Step 9:
Replace the Button Command with the new command.
Step 10:
Select the button variable and replace the first 0. It might take you a couple of tries to get it to snap to the right stop.
Step 11:
Open the variable tab and we will be making a new variable named Sonar.
Step 12:
Go to extensions and search for sonar and choose the one i highlighted.
Step 13:
Grab the set Sonar command and drag it under the if statement.
Step 14:
Drag the Sonar command into the sonar variable.
Step 15:
Next we will change the variables in the sonar command.
Step 16:
Open logic tab and drag the if else command under the Sonar command.
Step 17:
Open logic tab and drag the <0=0> command to replace the true statement.
Step 18:
Drag the Sonar Variable and replace the true statment.
Step 19:
Drag the continuous servo command under the second if statement.
Step 20:
Click on advanced and then open the control tab. Then drag it under the first 2 continuous servo commands.
Step 21:
Drag the second set of continuous command under the wait command.
Step 22:
Add a wait time under the second set of continuous servo command. Then drag the third set of continuous commands under the first else command.
Step 23:
Delete the other statements and leave the else if statement and the stop servo commands.
Step 24:
Drag the stop servo command under the else if statement.
Step 25:
Open the logic tab and drag a <0=0> command to the slot.
Step 26:
Drag a button variable to replace the 0
Step 27:
Now were going to change some of the variables.
Step 28:
This is what the finished code should look like.
