Introduction: Welding Chipping Hammer Stainless Steel - DIY
Welding Slag Chipping Hammer Stainless Steel
Dimensions
Blade 190x40mm
Shaft Ø10.5x155mm (at reality it was Ø10.47mm)
Handhold Ø18x115mm Including the corian ring (105+10mm)
Step 1: Tools
Tools
Remember Safety First.
Welding Cutting and Grinding Tools are Dangerous!
Do it at your own Risk!
Use Always the Suitable Protective Equipment.
Welding Machine - Mask - Gloves
Drill Press - drill vise
Angle grinder 115mm 4 ½” or 125mm 5” Angle grinder 180mm 7”
Cutting disk according to grinder ø115 x 1mm & 3mm/ø4 ½” x 0.04” or ø125 x 1mm/ ø 5” x 0.04”
Abrasive flat flap disk
Belt Grinder
Die Grinder (plus ø20mm consumables)
Abrasive Polishing machine
Tape measure, Caliper
Drill Bits ø3 - 3.3 - 4 - 4.2 - 7 - 10mm
Hole saw ø22mm
Center punch ø3mm, Pen Scriber
Circle Center Finder Tool
Flat File
Taps set M4x0.7mm & M5x0.8mm
Tap handle
Countersinks (two sizes)
Clamps
Bench Vise
Sand Paper
Emery Cloth
Scotch-Brite Num.7447
Step 2: Materials
All materials are stainless steel
Round bar: Ø10.5x185mm - Ø18x105mm
Flat bar or sheet metal strip: 45x200x4.3~4.5mm Final thickness after cleaning & polishing about 4~4.2mm
Bolts: 1pcs M4x10mm - 1pcs M5x20mm
Electrodes: E316L or any stainless steel that you have (needed less than one electrode)
Corian: 30x60x12mm or you can use brass or copper to make the rings
Step 3: Plans
You can print the photo or you can remake the plan by own.
Step 4: The Build
I designed the blade, printed in natural size and stuck over the blade.
With a fine punch I marked the centers of the contour nodes and drew the lines using a pencil scribe.
For the marking of the two curves I used a 10 cent euro coin (dia 19.75mm).
I did the cuts with an angle grinder and refine them using a file.
By a die grinder I refined the curves using Ø20mm consumables.
By a belt grinder I machined the faces of the blade removing all scratches and marks.
At the end it polished at an abrasive polishing machine.
I haven’t a lathe, so the drilling at the drill press is one way root for me.
But isn’t a so difficult job, neither a so critical If the center point of the hole isn’t 100% at the real center of the Ø18 axle.
So I set up a device with any I had on hands at the drill press bed.
Using my Circle Center Finder Tool I found the center of the axle.
You can see a How to at my Instructables project:
DIY Circle Center Finder Tool, Stainless Steel Made.
All the rest it was just a matter of perpendicularity and securing.
I decided to make the hole 10mm and not 10.5mm
because in fact it would definitely be a little bigger maybe 10.65 ~ 10.8mm.
Also one of my Ø10mm drill bits it was a short one and I thinking and less vibration.
Ι started with Ø4mm drill bit next Ø7mm and last Ø10mm.
Finally the hole was done Ø10.12mm.
Using the drill press and a file, I machined the one end of Ø10.5mm axle, to Ø10.1mm at the last 35~40mm.
I don't want to weld the two pieces together, so to be able to change the rings if damaged for some reason.
Also I have into my mind to replace them at a later time with brass or copper made rings.
I cut to length the two axels according to my needs.
Shaft Ø10.5x155mm - Handhold Ø18x105mm.
At the Ø10.5mm axle at the top of the shaft I made a 4mm notch where the blade will be placed. Using a screw I secured the blade to the shaft. Tack welds the blade with the shaft and took out the screw. Completed the welds and filled the hole that I had made for the screw.
I put the shaft in the Handhold and made an Ø3.3mm hole without digging out the opposite side. On the shaft I threaded M4 thread and on the handle I increased the hole from Ø3.3mm to Ø4mm. In the center of the lower part of the Handhold I made a hole 4.2mm and threaded M5 thread.
From a Corian piece using a hole saw 22mm I cut two pieces for the rings.
Using the drill press, I machined the two pieces and make them rings.
Please view the video carefully before proceeds to build without jumps.
Thanks for your reading.
Good Luck if you try it.
Never say I can't do it.
Necessity is the mother of invention.
kess
https://www.youtube.com/user/kessgr
http://www.homemadetools.net/builder/kess
