Introduction: What to Do With Old Broken Washing Machine?
Hello everyone who read this article! I'm Jayasanka Bandara and this is my first instructables article!
As I know, most people who searching about washing machines had seen a video like below!
After I saw that video, I thought 'What happened if I reuse something like that without destroy?'
So this is the article for how to use them usefully!
Step 1: Find What You Want
At our home, I didn't have old washing machine to do this. So I started to search in junkyards!
Finally I found a washing machine called Whirlpool AWT4085 with top load horizontal axis rotating drum and a lot of PCBs from old household appliances!
That machine is something like on top! (Picture1)
And the hardest part is get the machine out from my car! (Picture2)
Step 2: Prepare and Test It
Next, I had test it's parts with my trusty multimeter and unfortunately most of them are broken. There works only,
  • The motor
  • The drain pump
  • The heater
  • and The pressure switch
Step 3: Make a Plan for What to Do With It
As I said before there only 4 electric parts working fine. So I decided to make a spin dryer with it. Next, I powered up the motor and the drain pump.
After that, I planned a simple circuit using a light dimmer switch and 2 switches (1 for the drain pump).(Picture3)
Step 4: Find Parts and Set Them Up
As on Picture4 you can wire the universal motor.
Picture5 is after I built it up.
Step 5: Update for This Machine
Unfortunately, after 3 dries the dimmer had failed. (And I forgot to close the inner drum door :( and breaked the door) You must choose a good quality voltage regulator or universal motor controller. But I remembered that I got some PCBs from old appliances.
Thankfully 1 of them works (Picture6). But, there are 2 bad relays,1 bad cap and 1 bad resistor.
So I repaired it and I add to the machine.
Step 6: What to Do With Waste?
As I said before, there only 4 parts works. So what happen to rest of them?
There are a lot of wires in it and I keep other wires that the machine don't want.
And other keep other parts also because they can be useful at future!
I like to notice if you have a washing machine with only a bad control board (PCB) you can use a universal washing machine control board. (Picture7)
So finally I would like to say Thank You and your project will be also working well!
