Introduction: WiFi NodeMCU ESP8266 Google Clock
A simple easy WiFi clock using "Google" timestamp, with temperature, humidity and automatic brightness
Step 1: Schematics, Components
Components:
  • 1 x NodeMCU ESP 8086
  • 6 x MAX7219
  • 1x DHT22
  • 2x Resistor 10k
  • 1x LDR
Step 2: Code
You can download the code HERE
//V.3 - Data converted and daylight savings time
//V.4 - localized data, days... (use yours....)
//V.6 - thermometer and hygrometer
//V.7 - animated clock corrected + seconds +1,5
//V.8 - tuning thermometer and hygrometer
//v.9 - DST corrected / compiler error corrected (long)round
//v.10 - Date change at 00:00 corrected for GMT>0
//v.11 - automitc panel brightness (+3.3V ---|==10k==|---A0---|GND
// review: anthias64@gmail.com
// kudos original maker code can't find its name...
#include "Arduino.h"
#include
#include //ESP8266 Core WiFi Library (you most likely already have this in your sketch)
WiFiClient client;
#define NUM_MAX 6
// for NodeMCU 1.0
#define DIN_PIN 13 // D7
#define CS_PIN 0 // D3
#define CLK_PIN 14 // D5
#include "max7219.h"
#include "fonts.h"
#include "DHT.h" // sensor DHT
// DHT sensor
#define DHTPIN 12 // what pin we're connected to // GPIO 12 = D6
// Uncomment whatever type you're using!
//#define DHTTYPE DHT11 // DHT 11
#define DHTTYPE DHT22 // DHT 22 (AM2302)
//#define DHTTYPE DHT21 // DHT 21 (AM2301)
DHT dht(DHTPIN, DHTTYPE, 11); // for ESP8266
//DHT
float temperature = 0;
int temp = 0;
byte minus = 0;
int umidity = 0;
int poz, poz2;
int mult = 0;
float temp_offset = -1.0; // taratura termometro
float rh_offset = +3; // taratura igrometro
char TempLabel[] = " Temperatura: "; // Fixxed text
char UmiLabel[] = " Umidita': "; // Fixxed text
//modifica test ip
const char ssid[] = "xxxxxxxxxx"; // your network SSID (name)
const char password[] = "xxxxxxxxxxxxxxxxxxxxx"; // your network password
// Localized Months and DoWeek
String M_arr[13] = {" ", "Gennaio", "Febbraio", "Marzo", "Aprile", "Maggio", "Giugno", "Luglio", "Agosto", "Settembre", "Ottobre", "Novembre", "Dicembre"};
String Dow_arr[8] = {" ", "Lunedi", "Martedi", "Mercoledi", "Giovedi", "Venerdi", "Sabato", "Domenica"};
void setup()
Serial.begin(115200);
initMAX7219(); //
sendCmdAll(CMD_SHUTDOWN,1); //
sendCmdAll(CMD_INTENSITY,1); // brightness from 1 to 5
Serial.print("Connecting to ");
Serial.println(ssid);
WiFi.begin(ssid, password);
printStringWithShift("Connecting",30); //
delay (1000);
while (WiFi.status() != WL_CONNECTED) {
delay(500);
Serial.print(".");
Serial.print("IP number assigned by DHCP is ");
Serial.println(WiFi.localIP());
printStringWithShift((String(" IP:")+WiFi.localIP().toString()).c_str(), 30);//
delay(1000);//
// DHT
dht.begin();
temperature = dht.readTemperature() + temp_offset;
umidity = dht.readHumidity() + rh_offset;
Serial.print(temperature);
Serial.println(" gr.Celsius");
Serial.print(umidity);
Serial.println(" %RH");
if (temperature < 0)
temp = -10*temperature;
minus = 1;
else
minus = 0;
temp = 10*temperature;
// =============================DEFINE VARS==============================
#define MAX_DIGITS 20
byte dig[MAX_DIGITS]={0};
byte digold[MAX_DIGITS]={0};
byte digtrans[MAX_DIGITS]={0};
int updCnt = 0;
int dots = 0;
long dotTime = 0;
long clkTime = 0;
int dx=0;
int dy=0;
byte del=0;
int h,m,s;
float utcOffset = +1; // ==> your timezone
long localEpoc = 0;
long localMillisAtUpdate = 0;
int day, month, year, dayOfWeek;
int monthnum = 0;
int downum = 0;
int summerTime = 0;
String date;
String dayloc;
String monthloc;
void loop()
if(updCnt<=0) { // every 10 scrolls, ~450s=7.5m
updCnt = 60;
Serial.println("Getting data ...");
// clr();
printStringWithShift(" Get Time...",30);
getTime();
Serial.println("Data loaded");
clkTime = millis();
contrast(); // //autobrightness
//print data
if(millis()-clkTime > 30000 && !del && dots) { // clock for 30s, then scrolls for about 30s
printStringWithShift(" ",40); //Space before
printStringWithShift(date.c_str(),40); //data1
// Reading temperature or humidity
int umidity = dht.readHumidity()+ rh_offset;
float temperature = dht.readTemperature()+ temp_offset;
//umidity = umidity + rh_offset;
//temperature = temperature + temp_offset;
Serial.println("Temp e Umid corretti");
Serial.println(temperature);
Serial.println(umidity);
int t2 = 10*temperature;
// print temperature
// http://www.arduino-hacks.com/converting-integer-t...
char c[3], d[2];
String str1, str2;
int t2z = t2/10;
int t2u = t2 - t2z*10;
str1=String(t2z);
str1.toCharArray(c,3);
str2=String(t2u);
str2.toCharArray(d,2);
printStringWithShift(TempLabel ,40); // Send scrolling Text
printStringWithShift("+" ,40);
printStringWithShift(c ,40);
printStringWithShift("," ,40);
printStringWithShift(d ,40);
printStringWithShift(" C^" ,40);
//delay(2000);
// print umidity
char b[3];
String str;
str=String(umidity);
str.toCharArray(b,3);
printStringWithShift(UmiLabel ,40); // Send scrolling Text
printStringWithShift(b ,40);
printStringWithShift(" %" ,40);
//delay(2000);
printStringWithShift(" ",40); //Space after
delay(200);
updCnt--;
clkTime = millis();
if(millis()-dotTime > 500) {
dotTime = millis();
dots = !dots;
updateTime(); // get time
// print clock
showAnimClock();
//showSimpleClock();
void showSimpleClock()
dx=dy=0;
clr();
showDigit(h/10, 0, dig6x8);
showDigit(h%10, 8, dig6x8);
showDigit(m/10, 17, dig6x8);
showDigit(m%10, 25, dig6x8);
showDigit(s/10, 34, dig6x8);
showDigit(s%10, 42, dig6x8);
setCol(15,dots ? B00100100 : 0);
setCol(32,dots ? B00100100 : 0);
refreshAll();
void showAnimClock()
byte digPos[6]={0,8,17,25,34,42};
int digHt = 12;
int num = 6;
int i;
if(del==0) {
del = digHt;
for(i=0; i
dig[0] = h/10 ? h/10 : 10;
dig[1] = h%10;
dig[2] = m/10;
dig[3] = m%10;
dig[4] = s/10;
dig[5] = s%10;
for(i=0; i
} else
del--;
clr();
for(i=0; i
if(digtrans[i]==0) {
dy=0;
showDigit(dig[i], digPos[i], dig6x8);
} else {
dy = digHt-digtrans[i];
showDigit(digold[i], digPos[i], dig6x8);
dy = -digtrans[i];
digtrans[i]--;
dy=0;
refreshAll();
delay(10); //default 30
void showDigit(char ch, int col, const uint8_t *data)
if(dy<-8 | dy>8) return;
int len = pgm_read_byte(data);
int w = pgm_read_byte(data + 1 + ch * len);
col += dx;
for (int i = 0; i < w; i++)
if(col+i>=0 && col+i<8*NUM_MAX) {
byte v = pgm_read_byte(data + 1 + ch * len + 1 + i);
if(!dy) scr[col + i] = v; else scr[col + i] |= dy>0 ? v>>dy : v<<-dy;
void setCol(int col, byte v)
col += dx;
if(col>=0 && col<8*NUM_MAX)
if(!dy) scr[col] = v; else scr[col] |= dy>0 ? v>>dy : v<<-dy;
int showChar(char ch, const uint8_t *data)
int i,w = pgm_read_byte(data + 1 + ch * len);
for (i = 0; i < w; i++)
scr[NUM_MAX*8 + i] = pgm_read_byte(data + 1 + ch * len + 1 + i);
scr[NUM_MAX*8 + i] = 0;
return w;
int dualChar = 0;
unsigned char convertPolish(unsigned char _c)
unsigned char c = _c;
if(c==196 || c==197 || c==195) {
dualChar = c;
return 0;
if(dualChar) {
switch(_c) {
case 133: c = 1+'~'; break; // 'ą'
case 135: c = 2+'~'; break; // 'ć'
case 153: c = 3+'~'; break; // 'ę'
case 130: c = 4+'~'; break; // 'ł'
case 132: c = dualChar==197 ? 5+'~' : 10+'~'; break; // 'ń' and 'Ą'
case 179: c = 6+'~'; break; // 'ó'
case 155: c = 7+'~'; break; // 'ś'
case 186: c = 8+'~'; break; // 'ź'
case 188: c = 9+'~'; break; // 'ż'
//case 132: c = 10+'~'; break; // 'Ą'
case 134: c = 11+'~'; break; // 'Ć'
case 152: c = 12+'~'; break; // 'Ę'
case 129: c = 13+'~'; break; // 'Ł'
case 131: c = 14+'~'; break; // 'Ń'
case 147: c = 15+'~'; break; // 'Ó'
case 154: c = 16+'~'; break; // 'Ś'
case 185: c = 17+'~'; break; // 'Ź'
case 187: c = 18+'~'; break; // 'Ż'
default: break;
dualChar = 0;
return c;
switch(_c) {
case 185: c = 1+'~'; break;
case 230: c = 2+'~'; break;
case 234: c = 3+'~'; break;
case 179: c = 4+'~'; break;
case 241: c = 5+'~'; break;
case 243: c = 6+'~'; break;
case 156: c = 7+'~'; break;
case 159: c = 8+'~'; break;
case 191: c = 9+'~'; break;
case 165: c = 10+'~'; break;
case 198: c = 11+'~'; break;
case 202: c = 12+'~'; break;
case 163: c = 13+'~'; break;
case 209: c = 14+'~'; break;
case 211: c = 15+'~'; break;
case 140: c = 16+'~'; break;
case 143: c = 17+'~'; break;
case 175: c = 18+'~'; break;
default: break;
return c;
void printCharWithShift(unsigned char c, int shiftDelay) {
c = convertPolish(c);
if (c < ' ' || c > '~'+25) return;
c -= 32;
int w = showChar(c, font);
for (int i=0; i
delay(shiftDelay);
scrollLeft();
refreshAll();
void printStringWithShift(const char* s, int shiftDelay){
while (*s) {
printCharWithShift(*s, shiftDelay);
s++;
void getTime()
WiFiClient client;
if (!client.connect("www.google.com", 80)) {
Serial.println("connection to google failed");
return;
client.print(String("GET / HTTP/1.1\r\n\n") +
String("Host: www.google.com\r\n\n") +
String("Connection: close\r\n\n\r\n\n"));
int repeatCounter = 0;
while (!client.available() && repeatCounter < 10) {
delay(500);
//Serial.println(".");
repeatCounter++;
String line;
client.setNoDelay(false);
while(client.connected() && client.available()) {
line = client.readStringUntil('\n');
line.toUpperCase();
// Serial.println(line); //test stringa
if (line.startsWith("DATE: ")) {
//date = " "+line.substring(6, 22);
date =line.substring(6, 22);
date.toUpperCase();
Serial.println(date); //check
int day = atoi (date.substring(5,7).c_str()); //day number
int year = 2000 + atoi (date.substring(13,16).c_str()); //year number
monthnum = month2index(date.substring(8,11)); // convert month in mumber
month = monthnum; //check
downum = dow2index(date.substring(0,3)); // convert dow in mumber
dayOfWeek = downum; //check
monthloc = M_arr[month]; // localize month
dayloc = Dow_arr[dayOfWeek]; // localize DayOfWeek
date = dayloc + " " + day + " " + monthloc + " " + year;
// decodeDate(date); //data3
h = line.substring(23, 25).toInt();
m = line.substring(26, 28).toInt();
s = line.substring(29, 31).toInt()+1.5; //correzione ora
// summerTime = checkSummerTime();
// calcolo ora legale
Serial.print("Ora GMT: " );
Serial.print(h); //check
Serial.print(" : " );
Serial.print(m); //check
Serial.print(s); //check
Serial.println(""); //check
Serial.print("Data: " );
//day = 31;
//year = 2021;
//month = 10;
if(month>3 && month<=10) summerTime=1;
if(month==3 && day>=31-(((5*year/4)+4)%7) ) summerTime=1;
if(month==10 && day>=31-(((5*year/4)+1)%7) ) summerTime=0;
Serial.print("Summertime: ");
Serial.println(summerTime);
unsigned short MoZiff[12] = { 0, 3, 3, 6, 1, 4, 6, 2, 5, 0, 3, 5 }; //Monatsziffer
unsigned short Tage_Monat[12] = { 31, 28, 31, 30, 31, 30, 31, 31, 30, 31, 30, 31 };
if(h+utcOffset+summerTime>23) {
// if(++day>31) { day=1; month++; }; // needs better patch
// if(++dayOfWeek>7) dayOfWeek=1;
h = h - 24;
dayOfWeek = dayOfWeek +1;
if(dayOfWeek>7) dayOfWeek=1;
day = day + 1;
if (day > Tage_Monat[month - 1]) {
day = 1;
month = month + 1;
if (month > 12) {
month = 1;
year = year + 1;
date = dayloc + ", " + day + " " + monthloc + " " + year;
localMillisAtUpdate = millis();
localEpoc = (h * 60 * 60 + m * 60 + s);
client.stop();
//convert month string in month number
int month2index (String month)
String months[12] = {"JAN", "FEB", "MAR", "APR", "MAY", "JUN", "JUL", "AUG", "SEP", "OCT", "NOV", "DEC"};
for (int i = 0; i < 12; i++) {
if (months[i] == month)
return i + 1;
return 0;
//convert dow string in dow number
int dow2index (String dayOfWeek)
String dows[7] = {"MON", "TUE", "WED", "THU", "FRI", "SAT", "SUN"};
if (dows[i] == dayOfWeek)
return i + 1;
return 0;
//check if it is summer time
// int checkSummerTime()
//if(month>3 && month<10) return 1;
//if(month==3 && day>=31-(((5*year/4)+4)%7) ) return 1;
//if(month==10 && day<31-(((5*year/4)+1)%7) ) return 0;
//return 0;
// return 1;
void updateTime()
long curEpoch = localEpoc + ((millis() - localMillisAtUpdate) / 1000);
//long epoch = round(curEpoch + 3600 * (utcOffset+summerTime) + 86400L) % 86400L;
long epoch = (long)round(curEpoch + 3600 * (utcOffset+summerTime) + 86400L) % 86400L; // fix compiler error
//long epoch = round(curEpoch + 3600 * (utcOffset+summerTime) + 86400L);
h = ((epoch % 86400L) / 3600) % 24;
m = (epoch % 3600) / 60;
s = epoch % 60;
void contrast()
int lumina = analogRead(A0); //autobrightness (+3.3V ---|==10k==|---A0---|GND (niq_ro)
lumina = map(lumina, 0, 1023, 0, 4); //broghtness 0-4
//Serial.print("brightness = ");
//Serial.print(lumina);
//Serial.println (" / 4");
sendCmdAll(CMD_INTENSITY, lumina);
