Introduction: Wood Lego Man
When I was a kid I loved to play with lego. I saw a wood lego version on the internet so, I decided to create a lego man for myself.
I didn't record all the steps, but, there are the main ideas.
I don't have any machine that would help me cutting the most of figure parts so, there are a lot of hand work
Another think to have in mind, the wood boards were not so thick as I needed, so I had to glue 3 of them to have the figure thickness.
- Pine wood
- Wood pegs (for joins)
- Japanese saw
- Drill machine
- Clamps
- A lot of sand paper
- Wood glue
Step 1: Design and Measures
First of all, I like to write on a paper, do some drafts and get some numbers.
So I picked a small lego figure, get the measures and transported to a bigger version.
Then cut the bigger parts, all squared.
Step 2: Round It
After having all the pieces in squares, I rounded them up, using sand paper.
I rounded the head, hands, arms, legs
The arms was the most difficult part because it's angles, to cut it by hand I realized there were a lot of wood going to the flush.
The head have a circle on top and another below, witch were cut using the vertical drill machine
The hands, after round them up, I opened a hole in the middle with vertical drill machine and with the japanese saw I open the space and cut the bottom corners.
The legs had a challenge because the round top and leg, so I used a chisel so I can reach the shape I was looking for. Them round it on top with more sand paper.
Step 3: Joins
Between the body and legs there's a join, witch was grey zone until I stopped and spend some time looking to it.
So, once again, I got the circle from vertical drill machine and the join piece, with some time spending work and a saw I got there, to have it rounded so the circle fits there.
I fixed the circle with two wood pegs, so I get sure it will be well fixed.
From there I started the joins:
- Legs-to-body
- Leg-to-leg
- Body-to-head
- Arms-to-body
- Hands-to-arm
All this joins were made with wood pegs and glue
Step 4: Finished
I did not applied any finisher, at least, not yet.
I'm not sure about leaving as it is, or paint it, so for now it is on raw wood.
Step 5: Add Some Finish
After some time thinking on how to paint it, or leave it on wood appearance, the last one won!
So I applied some beewax (so the kids can play with it with no problems, no toxic stuff)
This is just an update on finish result.
