Introduction: Wooden Pendant / Necklace
This week i made a wooden necklace or pendant whatever you want to call it, from some off cut scrap wood.
Turned out better than i had hoped and i wish you could feel how smooth it is!!
Check the video out. Ive also got a few other project videos if your interested!
Follow my projects -
https://www.instagram.com/ggwoodprojects/
Consider supporting my projects-
https://www.patreon.com/GGWoodwork
Enjoy!
GG
Step 1: Finding Some Crap and Cut to Size
I used an off cut from an upcoming video but you can pretty much use any scrap you can find.
I drew out a line no idea on the measurements it just looked right and cut that out.
Step 2: A Ton of Sanding
Now i had my piece it was time to sand.
I used 80 grit to get the shape right, just a small angle at the top, and went on to smoothing .
I went though 80, 120,240,500 & finished at 1,200 grit.
It should feel like glass at 1,200 grit.
Step 3: The Cord
To attach the cord i used some 1mm clear elastic cord and a 2mm hole just down from the top of the piece to avoid it splitting on me,
I made the necklace around 31" long but you can make it as long or short as you want.
Step 4: Seal the Cord
To seal the cord i used some clear heat shrink tubing over the end.
I mainly did this because i would never have been able to tie a knot in 1mm cord but it also looks a lot nicer than just a knot .
Just make sure you dont melt the cord or your fingers - its not fun when you do that!!
Step 5: Job Done
I finished it with around 4 coats of spray lacquer, sanding lightly at 1,200 grit in between coats to keep the smooth finish.
And thats it! Job done!
I love how its turned out its really really smooth and shiny which is what i was going for.
the cord length is perfect , it just slides on and off your head but doesn't hang to low down.
I hope you enjoy and have a go yourself.
All in it took me around 2 hours to make and finish and cost about £0.50 for the piece of cord and heat shrink.
This would make a great gift for anybody you know or just have yourself to show off your work!
Follow my projects - https://www.instagram.com/ggwoodprojects/
Consider supporting my projects- https://www.instagram.com/ggwoodprojects/
Enjoy! GG
