Introduction: Wooden Stones Art Installation
Wood Stones is a proposed art installation that would take place in an indoor gallery space. The instructions listed below are for the prototype of the installation. The installation aims to create a sense of delight, curious and wonder for visitors to the site. With the use of a motion sensor, small motors attached to wooden stones begin to vibrate across the floor.
I am looking for suggestions to change the installation. What could improve it? One idea is to have the stones travel across sand so you can see the path they take.
Step 1: Materials & Tools
Materials
10 blocks of wood, 1.5” by 1.5” 10
mini motor discs - http://www.adafruit.com/product/1201
1 motion sensor - http://www.adafruit.com/product/1201
shift register 74HC595
E600 industrial strength adhesive
sandpaper
arduino uno
breadboard
solder
wires
holding pins
spray paint (optional)
Tools
belt sander
soldering iron
wire strippers
helping hands for soldering
fume extractor
Step 2: Make the Wood Stones
  1. Take the wood blocks up to a belt sander and create your unique stone shape.
  2. Break the edges of the dodecahedron by sanding with sand paper.
  3. Optional: Spray paint all sides of the stones in a well ventilated area. Let dry completely.
Step 3: Wiring the Motors and Connecting Them to the Wood Stones
  1. Prep the mini motor discs with some industrial strength adhesive to the base of the wires. This helps to prevent them from fraying over time.
  2. Take the mini motor discs and strip the ends of the wires to prep for solder. Be careful here as the wires are fragile.
  3. Solder wires to motors. To protect the joints you can use heat shrink tubing or hot glue. In this photo, I used industrial strength adhesive.
  4. Solder header pins to wires.
  5. Use industrial strength adhesive to adhere 1 motor to the bottom of 1 stone. Repeat 8 times.
  6. Take the motion sensor and solder holding pins to the ends of the wires.
Step 4: Wiring Your Breadboard
Wire the header pins according to the plan in the image.
The data sheet for the shift register can be found here.
Step 5: Upload Your Code
Upload the code for arduino.
