Wooden Tree
Elbee_ 'profile picture'
1.1K133
Intro: Wooden Tree
For the baby room, I had the idea to cut out a large tree in wood to hang teddy bears (or sugar beans first).
STEP 1: Print on Paper and Cut Out
First there was the search for a suitable image, in which all parts are attached to each other and not, for example, with loose leaves.
Once I found them, I printed them out on A4 paper.
I cut the tree completely with a cutter knife.
STEP 2: Project With Flashlight
Then I hung it on the ceiling of my workspace with clips and drawstrings so that it remained straight and could move as little as possible.
Behind that I placed a strong flashlight that projected the shape of the tree onto the MDF board.
It was mainly a question of finding the right distance between lamp and tree and between tree and MDF board.
STEP 3: Trace the Shadow on the Board
I completely traced the shadow of the drawing in pencil.
In order to avoid mistakes, parts are indicated as much as possible.
I placed my plate on 2 trestles to make sure I did not cut into my work table.
STEP 4: Remove Inner Parts
I first sawed all the inner parts with a seesaw.
The outer parts, last to maintain stability.
I first drilled a hole in every part for my saw to pass through.
After sawing I finished further with a file for nice curves and to remove saw marks.
STEP 5: Remove Outer Parts
Then I did the outer parts, but I always drilled a hole for my saw and did not cut to the edge.
I did that to maintain stability. It is clearer in the photo.
I still left large parts hanging together, later I remove these hatched parts.
STEP 6: Remove Top Half
Then I loosened the outer parts, sometimes I skipped one so that the tree would not fall through.
In the end I was able to remove the top half.
I also laid 2 extra pans across the trestles.
STEP 7: The Trunk of the Tree
Then I cut out the trunk of the tree.
I shifted the transverse pans so that it would not fall down and break off the branches.
Finally I cleared the bottom part of the branches.
STEP 8: Finish
With the pieces of surplus that I sawed away next to the trunk,
I made 2 legs so that the tree remains beautiful.
I'm definitely going to treat it, but don't know how yet,
maybe in brown / green, or else just a protective layer.
2 Comments
That looks so nice! This would be a lovely way to make an entryway coat rack :D
That's really neat how you made this large version using the flashlight :)
