Introduction: Wooden Waves
This is one of my most favorite projects that I have made and I hope you will enjoy it too
Wood
Dremel tool
Printer
Dremel tool
Printer
Step 1: Finding the Image
You can either draw the image or print it out I decided to draw mine
I found this part to be the most stressful because I wanted it to be perfect
Step 2: Carving
I first started out with a ball bit (in image)
And used the lines as the peaks of the carving
After I carved out the creases I took a sanding bit and sanded it all down
Last you want To sand it down with the sanding head
Step 3: Finishing
Lastly you want to coat the wood with polyacrylic 3 to 5 coats
Also you can use any kind of stain if you want to
