Introduction: Workshop Hanging Organizer
Trying to maximise the space in my little workshop I made this spool and tape organizer hanging from the roof
Its all constructed from 1/2 inch PVC it cost only a few bucks
Step 1: Cutting
You will need every thing in the image i dont put the measures it will be diferent acording to your roof and heigh
Step 2: Sawing
Cut 2 of this 90 deg angle couples like in the image
And 4 T couples make the same cut
Try to cut a little above from the middle allowing to press the pvc pipe and make click
Also drill 1 hole in 2 threaded end caps
Step 3: Ataching
Atach the end caps to the roof
Step 4: Organize
Glue all parts like the image the T couples are in different directions like in the image . screw the terminals to the endcaps atached to the roof , then add the long PVC pipes in the T facing the center and add some short pice to the ones facing the front
Hang all your spools in the center and all your tapes in the pipes facing the Front, Also you can make some spools for your wire using scrap MDF and some 1 inch scrap pvc pipe.
Hope this can get useful to some one
(sorry for the bad english its not my native language)
