Introduction: Zip Tie Dangling Earrings
These are easy dangling earrings made out of beads, wire, and a small zip tie. Enjoy!
Step 1: Materials
What you'll need:
- Three beads
- Jewelry pliers
- Small zip tie
- Three head pins
Step 2: Making the Beads
Start by putting your biggest bead onto a head pin. With your round-nosed pliers, make a large loop above the bead and cut off extra wire. Do this with all three beads.
Step 3: Putting on the Beads
Place beads on zip tie and pull the end through the other side of the zip as small as you want your loop to be. Cut off the extra zip tie.
Step 4: Adding Earring Hook
With your round-nosed pliers, make a large loop with the extra wire from the head pins. Open loop and add an earring hook and the zip tie loop.
