Introduction: Arrows for Paper Clip Bow
Need good target arrows for paperclip bow, well here they are they are accurate and can stick in wood.
Warning! these can puntcure skin
do not shoot at any living thing
Step 1: Supplies Needed
paperclip bow
straws
tape (eletrical or duck tape works best)
toothpicks
sizors
paper to make your own targets(I use paper frogs as shown inpic below)
markers for decoration (opitional)
straws
toothpicks
sizors
Step 2: Pre-parring Straws
This step you only need to do if you are using bendy straws.
Cut under the bendy part of the straw and keep the long end. These will be th arrow shafts.
Step 3: Putting the Points on the Arrows
Take the peice of straw and wrap some tape arround one end of it.
after you have wraped tape a couple times around one end make sure there is a hole big enough to stick the toothpic in it.stick the toothpic in half way and squeez the tape around it so it will stay.
this pic is of the tape wrapped around the arrowwithout tip.
Step 4: Making the Nocks
cut a little ways down the opposite side 2 times. make the cuts across from each other an put a piece of tape around the bottom of the cut so it dosent split the straw.
sorry about pic its aliyyle blury but its a pic of the knock
Step 5: Aim and Fire
take your bow and arrow and knock it on the rubber band.pull back ,aim and fire.if you w ant to see better pics e-mail me and i will send u better pics.
