Introduction: Bamboo Wine Holder
lets make bamboo wine holder without glue
Step 1: Tools and Material
Tools :
- saw
- axe
- sandpaper
- carver
- brush
- glasses
- Furnish
- hammer
Materials :
-bamboo
Step 2: Making Main Body Holder
the making of main body holder (wine body holder)
main body holder size :
30 cm x 12 cm
use sandpaper cc320cw for the tube to smoothen main body holder surface
and follow the bamboo fiber for the best surface.
Step 3: Making Sub Body Holder
(wine bottle opener) sub body holder :
25 cm x 10 cm
use sandpaper cc320cw for the tube to smoothen sub body holder surface
Step 4: Body Holder Hole (Wine Holder)
Body Holder for wine stand
Create two 3 cm diameter holes, length 5 cm or more (adapted),
measuring at 2 cm from each end of the tube,
chisel to make a hole,
and use sandpaper (follow the bamboo fiber for the best surface) cc320cw for smoothen the main body holder hole.
Step 5: Wine Handle
for wine handle
Create two 3 cm diameter bamboo , cut half of the bamboo
and use sandpaper (follow the bamboo fiber for the best surface) cc320cw for smoothen the wine handle.
Step 6: Sub Body Holder Hole
Sub Body Holder (wine opener)
Create two 1 cm diameter holes,
measuring at 8 cm from each end of the tube,
and use sandpaper (follow the bamboo fiber for the best surface) cc320cw for smoothen the sub main body holder hole.
Step 7: Wine Opener Handle
for wine opener handle
Create two 1 cm diameter bamboo , cut half of the bamboo
and use sandpaper (follow the bamboo fiber for the best surface) cc320cw for smoothen the wine opener handle.
Step 8: Wine Holder Rest
Wine Holder Rest
Cut a ring of bamboo with 3cm thickness.
Cut the bamboo ring into 2 equal semi circle parts,
sandpaper (cc320cw, follow the bamboo fiber for the best surface) the tube to smoothen its surface,
Sandpaper the whole surface of the tube to make as round as possible.
Step 9: Finishing
Finishing
Furnish the outer layer of the tube till it shines,
Wait for 30 minutes till it dries,
After drying, sandpaper (1000cc, follow the bamboo fiber for the best surface) the tube (inside and outside surface) to smoothen the all the bamboo surface.
or you can only use heatgun for finishing without furnish.
Step 10: Finish!!
bamboo wine holder
