Introduction: Cleaning Longboard Bearings
you wil need:
- aceton
- cleaning kit
- grease
- dirty bearings
- rags
- aceton
- cleaning kit
- grease
- dirty bearings
- rags
Step 1:
taken out the rubber ore steel protective cap of by using a needle ore paperclip.
Step 2:
put the bearings on the rod with a spacer between every bearing and put the screw on the end (make Sure the steel balls Are facing upwards).
fill the bottle 1/3th
Step 3: Shake It Off!
put the lid on top and shake for 30 seconds.
refresh the aceton en repeat until the aceton comes out clean.
Step 4: Drying and Oiling
dry your bearings and If you want use compressed air to blow out any residue.
put two drips of oil on the steel balls and give it a spin.
Step 5: Reassembling
put the caps back on and your doen!
