Introduction: Crochet Heart
this instructable tells you how to make this fun-looking, easy to make little heart.
I hope you like it :)
you'll need:
- a bit of yarn
- stuffing
- crochet needle
- a free morning/noon/evening (one of them will do, it's a small project)
The pattern
Make a chain of 20.
Now, in the fourth chain, counting from your needle, make three double crochets.
In the next five chains, you're gonna make one double crochet in each of them.
Now you need to crochet five double crochets together, I hope the picture helps.
Make one double crochet in the next five chains.
In the last chain, make seven double chrochets.(After that you can continue on the other side.)
Make one double crochet in the next seven.
Doubel crochet five in the next, to create the bottom of the heart.
Make three double crochets in the loop you made in the first step.
Close with a slip stich.
Chain three, then, in the same space, make one double crochet.
In the next three, make two double crochets.
Make one double crochet in the next three.
Crochet five double crochets together. (the same way as explained earlier.)
In the next seven, double crochet two.
In the next nine, double crochet one.
In the next one, double crochet five.
In the next three, double crochet two.
Make a slip stich to close this row.
Chain three, then, in the same space, double crochet one.
For the next part i I used a "rythm" one means: double crochet one in the next, two means: double crochet two in the next.
One, two, one, two, one, two, one, one, one
Crochet three double crochets together.(the smae way as explained earlier.)
Make a half double crochet.
One, one, two, one, two, one, two, one, two, one, two, one, two, one, two.
Eleven times one.
Double crochet five in the next.
Eleven times one.
Two, one, two, one, two
Now, continue making double crochets until you are at the end. There, make a slip stich to close the row and bind off.
Make two of these, sew them together and stuff it.
Now, you have a crochetet heart and I hope you like it!
you'll need:
- a bit of yarn
- stuffing
- crochet needle
The pattern
Make a chain of 20.
Eleven times one.
Eleven times one.
