Earphone Hub
Intro: Earphone Hub
Tired of sharing your earphones, and have to listen to half the music. But you don't want to spend money on it either.
then this is a solution to it.
ps: I excuse myself for any spelling mistake that might occurred, English is not my native language. But please correct me if I typed something wrong, we're all here to learn.
STEP 1: 1# What You'll Need
-jack plug (from the cable of old/broken/bad earphones)
-jack socket (from old electrical appliances)
-wires
-(hot)-glue
-an attractive case to put everything in
-some drill bits and a drill
-pliers
-electrical tape
-a soldering iron is handy but not necessary
the first step is to extract everything you'll need from the old appliances
since this is done by your own method and preferences (from destructive to poetic) I'm not going to show how to do that.
-wires
-(hot)-glue
-pliers
-electrical tape
STEP 2: 2# the Casing
-pop open the casing and make as many room as possible.
I chose a little toy car for this purpose, and I removed the wheel driving mechanism.
-figure out how you can get as many sockets in as possible and drill the holes make sure that the sockets barely fit, we want everything to be strong and secure.
I have 2 sockets in the roof of the car, and one in a wheel.
STEP 3: 3# the Plug & Sockets
-cut off the earphones of the old/broken earphones, so you're left with just the plug cable.
-strip off the protective plastic to expose the wires. they should have a factory color code
be sure to remember which of the wires should activate which ear (left right)
-connect every pin of the socket to a piece of wire and figure out which pin belongs to which wire from the plug
STEP 4: 4# Bringing Everything Together
-put every socket inside, and glue it with (hot)-glue so everything is strong and secure
-braid the associating wires and isolate the exposed metal with isolating electrical tape
-close everything up, and glue it shut.
now all you need is friends who want to listen to your music
or turn metal, and no one will bother listening to your music \nn/
good luck
NOTE: the sound level dropped once I plugged in the other earphones, this might be a failure in my design or because 2 earphones parallel consume more energy than I originally thought. any way it's solved by cracking up the volume.
just don't plug out one of the earphones when the volume is up! disconnecting one earphone will skyrocket the volume, and blast off your ears!
good luck
15 Comments
fraser02 9 years ago
That is awesome, very creative idea!!
thanks for sharing:)
saikishore 11 years ago
aeszok 12 years ago
Jakwiebus 12 years ago
If the car was a little larger, maybe a small amplifier would fit in, the schematics of small amplifiers can be found all over the Internet. But I had to remove an axle to be able to fit in 3 sockets, so there wasn't to much room to begin with, and I just anted a prove of concept :D
aeszok 12 years ago
makaylalovesyou 12 years ago
batman96 12 years ago
and indeed when I tested it with 3 bad earphones (free airline thingies that hardly work) the volume was a lot lower than with the better ones you see on the last picture.
just crank the volume up and it'll work fine. just remember to put it beck down again when one of the co-listeners is leaving the hub ;)
The only problem I've ever had with this type of thing, is that if you have to very different ear buds, one can be uncomfortably loud, while the other too quiet.
I would hook one jack up to a pot, so you can plug the loudest set into that jack and turn it down.
ironorr84 12 years ago
Taking it a step further and adding a battery powered amplifier and splitter would solve this.
the question is
is there room for it in a toy car?
blinkyblinky 12 years ago
