Introduction: Easy Bottle Cap Launcher
About: Future SEAL
In this instructable ,I'm going to show you how to make an easy ,iexpensive bottle cap launcher
Step 1:
you will need
rubber band
screws
nuts
something to use as a swing arm [needs to have a hole at both ends for the nuts and bolts]
bottle cap
scissors
hammer[optional but helpfull
Step 2:
first, take apart the door hinge
Step 3:
take the rubber band and cut it at the length you think is necessary and tie a knot connecting the two ends
[optional] tie a knot near the end
Step 4:
Take the side of the door hinge with three round ends and stick the pole that used to connect the two door hinge pieces together and insert it half way into the door hinge piece and stick the rubber band end with two knots on the pole
After you do that, you can hammer down the rest of the pole
Step 5:
next we are going to attach the swing arm
first, bolt on one end of the swing arm  to the body of the launcher [ don't screw in the nut to tight or the arm won't swing ]
after that' take the other screw and bolt it on the other side so that it will stick up a little on the arm
Step 6:
finally take the other end of the rubber band and wrap it on the bolt that is sticking up other swing arm and your done
to shoot the gun, put a bottle cap in front of the swing arm,pull the swing arm back and release
also if you want , you can put push pins in the cap
In the comments, tell me how far you can get yours to go. :)
