Introduction: Hacking Cube World
i have had this cube world for a longish time an decided to hack
Step 1: Opening
open it by reoving all the screws you see then it should butterfly open
Step 2: Killing Dat Noise
so if you own a cube world you know how annoying the noise can get so to shut just find the double wire in between the main circut broad and the gold thing (pizio). fun fact is you strip off the wire on the circuit boards end an put an led where the wires from the circuit bored and the ones from the pizio connect you the led will light up corresponding to the sound it would make
Step 3: Forced Tilting
if you use a wire or push butten to connect the secend solder connection to the others
Step 4: End
so thats all i know how to do so far if you can do somthing cool with this or have a hack i dont know leve it in the comments
