Introduction: How to Make a Halo Magnum
Step 1: What You'll Need
foam board
hot glue gun
exacto knife or another cutting object
scizzors
pencil or pen
white glue
electrical tape
sand paper
paint
paint brush
the computer you are using
and a printer
Step 2: The Templet
you will the want o cut it out
i would print more than one of the pic
Step 3: Foam Base
now you will want to go and trace out the templet on to your foam four times (if you do a gu like the magnum you dont want to trace the part where the the clip sticks out yet)
after that you can start to cut out the shapes. cut out the peices on the inside of the gun first
you have to be careful because the foam is thin and will bend and breack if you are not careful
Step 4: The Clip
then cut it out and sand the sides alittle so it will slide easyer
be careful this will make the gun tin where the clip is taken from and will bend if not careful
Step 5: Glueing It All Together
prelay out the order that they go on
start to glue them on layer by layer
another option is to use white glue but it takes longer
dont forget to glue the clip
Step 6: Sanding
dont sand to much or it will ruin the gun
Step 7: Giving It Shape
you will have to cut them out and trace them on to the foam
you will basicly repeat the last few steps with these peices
but for the sanding you can sand at an angle to make it flow better
Step 8: Painting
evenly paint the gun
do layers
take your time
make sure that the paint is acrylic paint other paints will eat your foam
if you dont have any acrylic paint you can coat the edges in glue and let it dry and then spray paint
Step 9: Finishing Up
and paint on more deitals
Step 10: Final Tips and Warnings
remember that this is a prop and is not real
dont take this in to public, if you are doing this for halloween costume paint the tip of it orange
remember you'll do such a good job they wont be able to tell
so dont run around to much with it in public or you will get shot by a real gun
