Introduction: How to Make a Paintball Gun!
i was trying to copy my friends marshmellow gun and during the process i realised that a paintball fit perfectly through 3/4 inch pvc pipe!
of course i tested it and it worked.
Step 1: Meterials
you will need 2, 90 or 45 degree connectors,2, 3 way connectors, and 1 or 2 long peices of pvc pipe, duct tape.
*make sure that the pvc pice is 3/4 inch*
Step 2: Assembly
to make a basic paintball gun design, follow these instuctions or you can skip this and make your own design.
1.cut a peice that is about 5 inches off one of the tubes and attach a 90 or 45 degree connecter on both ends facing opposite directions
2.next cut another peice off that is about 2 1/2 inches and attach to the connecter
3.take one of your 3 way connectors and attach it to the other side of the 2 1/2 inch pipe
4.cut off another peice that is about 4 inches and attach it to the bottom part of the three way connector
5.cut off yet another peice that is about 8 inches and attach it to the only remaining side of the first 3 way connector
6.take the other 3 way connecter and attach it to the other side of the 8 inch tube
7.cut off a 4 1/2 inch peice of pipe and atttach to the 3 way connecter facing upwards
8.lastly, cut off a 10 inch peice of tube and attach it to the last side of the 3 way connecter.
thats it!!
thats it!!
Step 3: Shooting
to shoot, blow through the exposed end of the 90 or 45 degree connector.
the FPS (feet per second) depends on how hard you blow.
Step 4: Loading
to load the gun, simply put a paintball in the barrel of the gun. easy!
Step 5: Paint a Forest
you probably wont be allowed to shoot at your house unless you own a lot of property so find a nearby forest and paint it! remember, always were sefly goggles.
*for better use duct tape all exposed ends exept for the barrel and blowing tube*
