Introduction: 8-Shot K'nex Gun
I was messing around with KillerK's Magnum, and found i could make it hold 8 shots. I figured i may as well post it - it is a whole new type of reloader (i'm pretty sure it is) The farthest I got it to shot was about 13 yards. The shortest was 7 yards.
Special thanks to KillerK for his magnum.
Step 1: Building the Barrel
These are the instructions for building the parts of the barrel - some of them will be put together now, others put to the side for later attachment.
1.) Build these
2.) Put the yellow connector pieces on to the specific pieces
3.) Then attach them with green connectors (The yellows)
4.) Connect these two parts
5.) Attach step four to this
6.) What you should have now
7.) Build these for later
And your done with this part
1.) Build these
Step 2: Building the Handle
This is how you build the handle for the "Magnum"
1.) First attach these green pieces to the red rod. 10 green connectors.
2.) This is what it should look like.
3.) Connect the two yellow connectors to a different rod like so.
4.) Then slide the red rod with the yellow connectors onto the red rod with the green connectors.
5.) this is what you should have. Please note that the yellow connectors DO NOT snap onto the red rod with the green connectors on it. (See picture 6)
6.) The yellow connectors shown here, not connecting.
7.) Put on these two gray connectors, and then put five more green connectors on, so they look similar to the first ten.
8.) This is what you have now.
9.) Build these two things, and then set them aside with the handle for later.
Done with the handle construction now.
Step 3: The Revolving Reloader
This is the part that allows you to hold 8 "bullets" at once, with no need for manual reload.
1.) Build THREE of these.
2.) Build THREE of these. (slightly different from the first!)
3.) Connect them all with a blue rod, using the spaces in the first three for the connection.
4.) This is what you have so far.
5.) Slide a grey rod through the center of the whites.
6.) Put one of these on each side, to hold it in place.
7.) this is what you have.
That is the Reloader part.
Step 4: Building the Firing Pin and the Important Upper Part Thingy.
These are important parts to the function of the gun.
1.) Build this
2.) Attach a yellow rod to the firing pin.
3.) Put a rubber band on it like this. a problem with my gun is that the firing pin needs to be long. When i don't put a rubber band around mine, it breaks.
4.) Build this
5.) Put your two rubber bands in-between the connectors.
6.) Put a blue on the top.
That is those parts finished
1.) Build this
4.) Build this
Step 5: Trigger
This is the trigger. People, please don't get angry at me for needing a brokne piece. Hopefully, you have built KillerK's Magnum, and already have one of these. If not, then break off the top part of the green connector using a hammer and a screw driver.
1.) This is what the connector should look like.
2.) Put it on a white rod, with these things on both sides.
That is the trigger.
Step 6: Connecting the Parts Part One
This is how you connect all the parts together, in order to make the gun.
1.) Attach the handle to the part of the barrel that has the lose orange connector on it.
2.) Attach those two pieces you built earlier for the trigger.
3.) At the front of the piece that has the handle on it, attach these three red pieces. (The could be any color except white, really.)
4.) Go ahead and set the firing pin in place on top of the barrel part.
5.) This step is a bit of a jump, so stay with me. First, get one of the pieces that you built just after building the barrel, and set it on top of the existing build. Then pick up the top half of the barrel, and hold it in place. Then place the other re-inforcing piece on the back - just hold it for now.
6.) place these three blues on to hold the reinforcements in place.
Step 7: Connecting the Parts Part Two
The second half of completion.
1.) Attach the "Thingy" to the fron end of the barrel. The two greens on the bottom area of the yellows should connect to the bright yellow connectors (in my model). Go ahead and put the rubber bands onto the firing pin.
2.) Attach the trigger. Make sure the broken part is facing the handle.
3.) This shows where one side of the rubber band goes to make the trigger system work. It goes UNDER the "floating" orange piece, with the green rod on the floating piece faces the end of the barrel.
4.) showing the other half of the rubber band for the trigger.
5.) These just keep the whites out of the way. The whites are safties, but I dont use them :)
6.) take the Reloader, and just slide the gray piece into the three connectors at the front.
7.) This is what it should look like. YES IT SHOULD BE CROOKED.
8.) Put a rubber band on the gray rod, and then put a gray connector in between it. Then put it where it shows.
Step 8: Preparing the Gun.
This is in detail how to load the gun.
1.) This is what i use for ammo. Red rods don't go very far, and blue rods are to short. The ends could be anything, I guess.
2.) First, wind the reloader so that the gray connector next to the rubber band goes around twice. Hold the reloader in place, and cock the firing pin back.
3.) Put one bullet into the chamber that is nearest to the firing area. Once it is there, you can let go of the reloader. Then go ahead and place the other 7 bullets into the holes. (sorry picture got cut off)
Step 9: Firing the Gun
Not much to be put here, but:
1.) When you fire the gun, mind your fingers - you dont want the firing pin to hit them.
2.) After each shot, you have to recock the firing pin. Sorry, I don't know how to make a semi-automatic
3.) Don't go shooting someone/something. It doesn't hurt to much, but it is annoying.
4.) If you have any siblings, don't tell them how to use it, they will just shoot you.
Happy Hunting!
Happy Hunting!
