Introduction: AWESOME TREEHOUSE
This treehouse is a great way for you to spend time with the people you like
but now for the serious stuff
NOTE:IT IS QUITE A HARD INSTRUCTABLE AND WILL TAKE LONG TO BUILD
Step 1: WHAT YOU NEED
lots of thin wood
lots of thick wood
nuts, bolts and washers
screws
a tree
screwdrivers
a ladder
drill
jigsaw
Step 2: BUILDING
First you need a tree it must have at least 3 strong branches surrounding a space a few metres by
a few metres
Now you must make a base from the thick wood and  it must be a bit bigger than the size you want your treehouse to be Using screws attach the base to the treecut
take your decking  cut it to size and ah it to the base
Now you need to make the sides cut 2 lengths of  the thich wood  for each side and  use thin wood as the support for the top piece now screw the sides to the base
Step 3: FINISHING OFF
 You now need to  cut a space for the door take the saw and cut a space in the railing then put the ladder coming up prom the ground  you also need to varnish or paint it(I recomend using 2 coats of marine varnish)
Step 4: DECORATING
your treeouse is probobaly looking a bit bare so here are a list if things you can do to make it look better you can put in some
tables
chairs
lights
a trapdoor
a sign (any kind)
a roof
a gun
