Introduction: Airsoft Claymore
A simple airsoft Claymore made from a party popper.
idea found here
http://www.geocities.com/usafcaptain/claymore.htm
EDIT: The link above is dead. Sorry.
And wow, Its been awhile since I posted this. Since then I've found that, even with corn instead of BBs, this doesn't work except in scenarios where the triggering of the device itself is considered a kill, at which point you might as well leave in the confetti.
Step 1: Supplies
1.partty poppers
2.fishing line.
3.BBs
4.long thin object(like a knife or pencil)
5.nails.
Step 2: Make
CAREFULY remove the paper circle that holds the confetti in.
You will need that later.
Remove confetti.
Fill with BBs.
Replace paper circle.
Step 3: Setup
use the eyelet screws to attach the popper to a tree or some thing.
tie fishing line to the end of the popper string.
run line accros chosen space.
Expeirement to best suit you needs.
Step 4: Other Uses
attach to a weapon to use as a shotgun.
leave empty, then trigger to scare the crap ouy of enemies.
Iow, I thought Id think of more, somebody comment and tell me another use I can put in here.
