Introduction: Straightening and Stiffening a Wire (enderezando Y Haciendo R�gido Un Alambre).
About: I am leaving Instructables, soon. I am very upset with the turnaround that has the page to post the manufacture of a dildo. Me llamo Osvaldo Julio Schiavoni I speak Spanish, not English. I use automatic tran…
EDITED 05 feb 2011:
I discovered, years ago, an easy, cheap and efficient way to straighten and stiffening a wire:
An end of the wire is put in the electrical drill, the other end to some hook or vise, tense the wire and rotate the drill a few turns.
The result is surprising.
This method is useful to construct axes or straight rods, and even to make springs. It can be used on thick (all you can manage, obvious) or thin wire.
That is all, folks.
Descubrí, hace años, una forma fácil, barata y eficaz de enderezar y dar rigidez a un alambre:
Un extremo del alambre se pone en el taladro eléctrico, el otro extremo se fija a un gancho o a la morza, se tensa el alambre y se gira el taladro unas pocas vueltas.
El resultado es sorprendente.
Este método es útil para construir ejes o barras rectas, e incluso para hacer resortes. Se puede utilizar en alambre grueso (todo lo que uno pueda manejar, obvio) o delgado.
Eso es todo, amigos.
Step 1: Discovered September 19, 2011
Popular Mechanics (Spanish version) said this in 1955
I am not too misguided, you can see.
