Introduction: Cat Bag Charm
A cutie easy to make bag charm
Step 1: Lets Get Making
Things you will need:
-big pendant bead i used a plastic cat bead
- smaller pendant beads i used plastic ice cream beads
-plastic star beads
-clasp
-1 large jump loop
-lots of smaller jump loops
-head pins
-chain
-pliers
Step 2: Step 1
First of all you will need to attach the chain onto the clasp. Use cutters to cut the chain. Use pliers to twist apart the large jump loop and place the clasp and chains inside.
Twist the loop back into place to trap the clasp and chains inside.
Step 3: Step 2
Next attach the big bead to a shorter bit of chain. Using pliers twist a small jump loop open trap the bead and chain inside and twist back into place.Attach smaller beads
to other chains i used ice cream beads.
Step 4: Step 3
Star beads. You will need to add a loop to the star beads so you can attach them. To do this you will need to use a head pin and pliers.Push the head pin through the star bead and cut down to size using the wire cutters .Then push the top over .Now you will need to grab the end of the wire head pin with the round nose pliers twist your wrist back to create a small loop at the top of the star.
Step 5: Step 4
Add the stars using jump loops as i showed you in previous steps
Step 6: Finnished!
