Introduction: Cemetery Columns
About: I love doing things on my own. Once I discovered this website I was hooked.
I started a graveyard a few years ago but I wanted to have a creepy entranceway so I built these and I put an air cannon in one and I scared allot of people.
Step 1: Column
The column is easy to make just time consuming. Adjust to the height and width you want.
Materials
2x4 for the base and top.
2 sheets of thinnest plywood I could find. I didn't want them to be heavy.
2 sheets of pink foam insulation.
I ripped 2 2x2x8 into 4 pieces each for the structure height.
Liquid nail to glue foam on. Black and grey paint.
Step 2: Column Details
After I built them and added the foam I wanted detail. I used a sharp knife and just scraped all the edges to rough them up. This makes them look old and weathered. Then I painted all the roughed up spots black for depth before the grey. Draw cracks any way you want but I used several methods to carve the cracks. The fastest is a Drexel but they don't look as realistic the best way was with an exacto blade but is time consuming. Again fill them in with black.
Step 3: Painting.
Add a base layer of black on the whole column then pint it grey but be careful not to fill in the cracks. I decided rolling them was better than spray painting. Then take a can of dark grey spray paint and spray in bursts of a circular motion. I also used spray glue and added moss to create an aged look. The moss I got from the dollar store.
Step 4: Air Cannon
This is out of step but I built an air cannon from pvc and a sprinkler valve. The air cannon was hooked to an atv battery I had and I ran some fittings to connect it. I only pushed 35 psi through because it makes a loud horn sound any higher but that was enough.
