Introduction: Crochet Haunted House
About: I like sewing and crafts,and trying new things. I'm vegetarian and always looking for new recipes. My cat's name is Mirko and likes to be in the centre of things, so you will see him in several of my instruc…
Here is my crochet haunted house, with a ghost, witch, zombie (er half zombie) and skeleton, plus a spooky tree, some pumpkins and an ominous figure in the window.
To bring this scary scene alive, I added some special effects, there are lights inside the house and in the pumpkins and the ghost glows in the dark. When you press on the coffin it plays the monster mash.  Likewise, when you press on the zombie he laughs maniacally.  And with the help of a servo motor the witch and ghost chase each other in a circle above the roof of the house.
To  go directly to pattern:
Step 1: What We Will Need
Yarn:
  • Yarn weight 4: Black ,Off-white, white, grey, green, orange
  • Size 10 crochet thread: white
  • Black and red embroidery thread
Other:
  • 2.25mm and 1.15mm crochet hook
  • Yarn needles
  • 5mm doll eyes
  • Polyfil/fibrefil stuffing
  • Black felt- one large piece and some small scraps
  • Brown felt
  • Scrap of fabric for zombie shirt
  • Bamboo skewer and raffia for witches broom
  • A bit of roving (grey, brown etc for ground)
  • (optional) Glow in the dark paint or glow in the dark yarn for ghost)
  • For servo motor: some small bits of wood and a clear plastic platform
  • Cardboard
  • Floral stem wire
Electronics
  • LED Christmas lights (white)
  • Mystery SD 3.7 Servo motor
  • 6V battery pack or AC adapter
  • Music module from Halloween toy
  • Laughter module from toy
Use the 2.25mm crochet hook unless indicated otherwise.
Here is the nomenclature that I used for the crochet pattern (these are US stitches see link for conversion to UK):
            Rnd         round
            ch(s)       chain stitch(s)
            sc            single crochet
            hdc          half double crochet
            sl st         slip stitch
            sk            skip
            st(s)        stitch(s)
            sc2tog    decrease by crocheting 2 stitches together
Step 2: Ghost
Ghost
With white yarn:
Rnd1: 6 Magic Circle
Rnd2: 2sc in sc (6sts)
Rnd 3-7: sc in sc (12sts)
Rnd8: *2sc in sc, sc, sc (repeat from*) (16sts)
Rnd9: 2sc in sc (32sts)
Rnd10: 2sc in sc (64sts) Fasten off, Leave tail
I then dilluted some glow in the dark paint with water and dipped the ghost into it. Once dry I added two felt circles for eyes.
Step 3: Skeleton
The entire skeleton is made with off white yarn.
Head
Rnd1: Magic Circle 4
Rnd2: 2sc in sc (8sts)
Rnd3: sc in sc (8sts)  stuff head
Rnd4: sc2tog, sc, repeat (6sts)
Fasten off. Leave tail.
Ribs
Rnd1:  Magic Circle 6
Rnd2: *2sc, sc (repeat from*)(8sts)
Rnd3: *2sc, sc (repeat from*)(12sts)
Rnd4-5: sc in sc (12sts) Fasten off, Leave tail
Pelvis
Rnd1: 4 Magic Circle
Rnd2: 2sc in first, sc in rest(5sts)
Rnd3:  2sc in first and 3rd, sc in rest(7sts)
Rnd4: 2sc in first and 4th, sc in rest (9sts)
Rnd5: Fold flat and stitch across the top to close.
Arms (make 2)
Magic Circle 3, 6ch(s), sl st in 2nd from hook.
Legs (make 2)
Magic Circle 4, 8ch(s), sl st in 2nd from hook.
Step 4: Skeleton Assembly
To put the skeleton together, I made 8 chain stitches from the base of the head slipped it through the top of the rib cage and connected it to the top of the pelvis. I then attached the legs to the pelvis and the arms to the top of the ribs. I added two felt circles for eyes and stitched a mouth with embroidery thread.  I then made a noose with rough cord to hang poor skely from the tree.
Step 5: Witch
Robes
With black yarn:
Head
With off white yarn.
Rnd2: 2sc in sc (12sts)
Rnd3-5: sc in sc (12sts) stuff head
Rnd6: sc2tog in each
Hat:
With black yarn:
Starting in the middle
Rnd1: 12chs, sl st in first
Rnd2: 2sc in sc (24sts)
Rnd3: 2sc in sc (48sts)
Go back to the first round and in the other direction:
Rnd2a: sc in sc (12sts)
Rnd3a: sc2tog in first, sc in sc in rest (11sts)
Rnd4a: sc2tog in first, sc in sc in rest (10sts)
Rnd5a: sc2tog in first, sc in sc in rest (9sts)
Rnd6a: sc2tog in first, sc in sc in rest (8sts)
Rnd7a: sc2tog in first, sc in sc in rest (7sts)
Rnd8a: sc2tog in first, sc in sc in rest (6sts)
Rnd9a: sc2tog in rest
Fasten off. Weave in ends.
Arms
With black yarn:
Rnd2-19: sc in sc (4sts)
Rnd20: sc2tog in each
Nose
chs 2
Rnd 1: 2sc in 2nd ch(s) from hook
Step 6: Witch Assembly
To assemble the witch, sew the nose to the centre of the face. Add plastic eyes.  I added hair using black textured yarn. I cut the yarn in strands twice the length that I want the hair to be and hooked it through the holes in the head.(See this for instructions. ). Cover the head with hair and trim with scissors to make it look nice. Stitch the hat to the head and head to the body.  Stitch one end of the arm to each shoulder forming a loop.
The witches broom is made by tying some raffia to part of a bamboo skewer and then secured it to the underside of the witch and through the arm loop.
Step 7: Zombie
Use green yarn for the zombie, except for the eyes.
Head
Torso
Rnd3-9: sc in sc (12sts)
Arms (make one short and one long)
Rnd2-5: sc in sc (4sts) for long
Rnd2-3: sc in sc (4sts) for short
sc2tog in each
Eyes
With white size 10 thread and a 1.15mm crochet hook
Rnd1: Magic Circle 2
Rnd2: sc in sc (2sts)
Step 8: Zombie Assembly
I used french knots with back embroidery thread for the pupils of the eyes and the mouth. I stitched one eye directly to the head.  The second eye was attached loosely with red embroidery thread.  I also made some stitches with red thread on the end of  the short arm.  I added a bit of brown hair to the top of the head (see step 6 about adding hair).  I stitched the head and arms to the torso.  I sewed a shirt from some scrap fabric and dirtied it up a bit with coffee grounds and red paint.
The laughing sound module fits right inside the torso.
Step 9: House
House walls:  ( I made the walls uneven to make the house look warped)
With grey yarn:
Back wall: (the back doesn`t have any windows)
Row1: ch21, turn
Row2-30: sc in sc across , ch1, turn. Gradually increase the stitches until there are 32st across (20-32sts)
Side wall: (make 2)
Row1: ch21, turn
Row2-12: sc in sc across , ch1, turn. (20sts)
Row13-21: sc in sc in first 6 , sk 8, sc in sc in last 6 ch1, turn. (20sts)
Row22-30: sc in sc across , ch1, turn. (20sts)
Front Wall:
Same as back wall except to add windows:
Row16-12: sc in sc roughly 1/5th of the way across, skip 1/5th, sc in sc  1/5th ,skip 1/5th, sc in sc  1/5th
Roof
With black yarn
Front and back: (make 2)
Row1: ch36, turn
Row2: sc in each st, ch(s)1 turn (35sts)
Row3-10:Sc in first 2 sts, *ch 1, sk next st, sc in next st; rep from * across to last 2 sts, sc in last 2 sts
Sides: (make 2)
Row1: ch24, turn
Row2: sc in each st, ch(s)1 turn (23sts)
Row3-10: Sc in first 2 sts, *ch 1, sk next st, sc in next st; rep from * across to last 2 sts, sc in last 2 sts
Decrease one stitch starting Row 3 until
final row has 16sts.
Roof top:
Row1: ch36, turn
Row2-16: sc in sc across , ch1, turn. (36sts)
Chimney
With grey yarn
Rnd1: ch(s)20 sl st in first (20sts)
Rnd2-4: sc in sc (20sts)
My chimney fits snugly around the servo motor, if you are using a different motor you may need to adjust the size of the chimney.
Step 10: House Assembly
Stitch the house together front to side to back to side to front.  Likewise with the roof.  Sew the chimney onto the top of the roof in the centre.  Sew a square of black felt to the front of the house for the door.  Cut out strips of brown felt "boards" to cover all but one of the windows.  Cut out a ominous human-like shape from black felt and attached to the inside of the unboarded window.
For structural support I cut of pieces of cardboard the same size and shape (including the windows) as the walls.  Taped them together at the edges and stuck it inside the house to help it stand on its own.  I also used cardboard to support the roof.
I cut 2 small pieces of wood roughly the same size as the servo motor and another piece to fit underneath the motor.  I sandwiched the motor between the 2 pieces of wood and on top of the third and taped it all together to stabilize motor.  This fits snugley inside the chimney.
Step 11: Other Stuff
Pumpkin (I made two)
With off orange yarn. Don't stuff
Stem:  With green yarn chain two and stitch into top of pumpkin.
Coffin
With grey yarn.
Top:
Row1: ch11, turn
Row2-7 : sc in sc across , ch1, turn (10sts)
Side:
Row1: ch38, turn
Row2-4 : sc in sc across , ch1, turn (37sts)
Sew the side piece to the top.  Cut and glue on a cross with black felt.  The coffin fits over the sound module.
Tree
With brown yarn, add stuffing as you go
Trunk:
Rnd1: Magic Circle 10
Rnd2: *2sc in sc, sc (repeat from * ) (20sts)
Rnd3: *2sc in sc, sc, sc (repeat from *) (30sts)
Rnd4-6: sc in sc (30sts)
Rnd7: *sc2tog in first, sc (repeat from *) (20sts)
Rnd8: sc in sc (20st(s)
Rnd9: *sc2tog in first, sc (repeat from *) (10sts)
Rnd10-15: sc in sc (10st(s)
Rnd16: *sc2tog in first, sc (repeat from *) (9sts)
Rnd17: *sc2tog in first, sc (repeat from *) (8sts)
Rnd18: *sc2tog in first, sc (repeat from *) (7sts)
Rnd19: *sc2tog in first, sc (repeat from *) (6sts)
Rnd20: *sc2tog in first, sc (repeat from *) (5sts)
Rnd21: sc in sc (5sts)
Rnd22: sc in sc (5sts)
Rnd23: *sc2tog in first, sc (repeat from *) (4sts)
Rnd24: sc in sc (4sts)
Rnd25: sc in sc (4sts)
Rnd26: *sc2tog in first, sc (repeat from *) (3sts)
Rnd27: *sc2tog in first, sc (repeat from *) (2sts)
Rnd28: *sc2tog in first, sc (repeat from *) (1sts)
Rnd29: ch1 (1sts)
Branch 1: (add stuffing as you go)
Rnd1: Magic Circle 8
Rnd2-4: sc in sc (8sts)
Rnd5: *sc2tog in first, sc (repeat from *) (7sts)
Rnd6: sc in sc (7sts)
Rnd7: *sc2tog in first, sc (repeat from *) (6sts)
Rnd8: sc in sc (6sts)
Rnd9: *sc2tog in first, sc (repeat from *) (5sts)
Rnd10: sc in sc (5sts)
Rnd11: *sc2tog in first, sc (repeat from *) (4sts)
Rnd12: sc in sc (4sts)
Rnd13: *sc2tog in first, sc (repeat from *) (3sts)
Rnd14: sc in sc (3sts)
Rnd15: *sc2tog in first, sc (repeat from *) (2sts)
Rnd16: sc in sc (2sts)
Rnd17: ch3
Branch 2: (add stuffing as you go)
Rnd1: Magic Circle 5
Rnd2: sc in sc (5sts)
Rnd3: *sc2tog in first, sc (repeat from *) (4sts)
Rnd4: sc in sc (4sts)
Rnd5: *sc2tog in first, sc (repeat from *) (3sts)
Rnd6: sc in sc (3sts)
Rnd7: *sc2tog in first, sc (repeat from *) (2sts)
Rnd8: sc in sc (2sts)
Rnd9: ch3
Stitch the two branches to the tree.  Since the tree will need to support the weight of the skeleton, I used some floral stem wire that ran through the length of the trunk out the bottom.
Step 12: Putting It All Together
Ground
I used a sturdy piece of cardboard with black felt laid on to top for the ground.  I added some roving onto the felt so it didn't look so plain.
House
I placed the house along the back edge. I placed the string of lights inside the house except for 2 lights at the end which I pulled out the front of the house (under the felt). I cut two slits on either side of the door in the felt pulled the lights through and stuck the pumpkins on them. The battery supply sits behind the house, out of sight.
Tree and skeleton
The tree was place to the right in front of the house and hung the skeleton from the trunk (attaching it to the floral stem wire) to help support the weight of the skeleton I stuck the wire through the bottom of the tree into the cardboard underneath.
Zombie
I put the laughter module inside the zombie.  Then I stuck a thumbtack into the felt near the front of the scene and placed the zombie over it.  The sound is activated by a little button on the underside of the module. So when you press down on the zombie the spring is depressed and the button hits the top of the thumbtack and the sound is played.
Coffin
I placed the coffin just behind the zombie covering the music module.  The music module is activated by pressing the top of the coffin.
Ghost and witch
I used a clear piece of plastic (I believe it was packaging from my Itouch) as a platform for the witch and ghost.  I drilled a hole in the centre of the platform and screwed it onto the servo motor.  I glued the witch and ghost to either end of the platform, facing opposite directions (check which way the servo spins so that they are facing forward as it turns). I used a 6V AC adapter to power the servo.
