Introduction: Fairy House Lamp Using Plastic Bottles
Hello, in this tutorial I show you how I made a fairy house lamp using nothing but coca cola plastic bottles, tin foil, paint, hot glue and paper clay
Step 1: Adjusting the Plastic Bottles
I first cut the bottoms of the large bottles, and adjusted the length of the small one. I then glue the coke bottles together.
Step 2: Shaping the Fairy House With Tin Foil
Build the shape of the house using tin foil and hot glue. This is a fast way to achieve a basic volume that will be the base for our paper clay. You should have the general shape of your fairy house in no time. Next we will draw the locations of the windows and door of the fairy house. Considering it will be a lamp you should draw as many windows as you can so the light will come out nicely.
Step 3: Cover With Paper Clay
You can now cover everything with paper clay. (I used "Das modelling material" but you can use Keraplast or any paper clay or even a homemade paper clay - I have a video about that on my YouTube channel) I use paper clay because it doesn't shrink like normal air dry clay. So don't use natural air dry clay, it will shrink and that will result in a lot of cracks around your bottles.
You can work in one layer or, if you are a beginner you should work in two layers, one for covering the surface and the second one for the details like wood texture, roof tiles, chimney, door steps. After the paper clay is dry you can easily add more details using tin foil and hot glue. For example I added some wood under the little balcony. The roof tiles should be placed starting from the bottom of the roof and working your way up. Let everything dry.
Step 4: Painting and TADA!
I used watercolors and watercolor crayons for painting because I like working in layers and be able to change if I don't like the way it looks. You can also use acrylic paint. It's up to you. In the end you can seal the paint using some matte spray varnish. I placed some battery LED lights under the house. I recommend you use soft lights that will gently illuminate your windows so it looks like a real house. DON'T USE HEAT EMITTING LIGHTS!
I hope you like my project. See you!
