Introduction: Fancy Hard Boiled Eggs
Did you know you can form hard boiled eggs into different shapes. It's quite easy to do.
The trick is to use a newly boiled egg that is still hot.
Step 1: Materials Needed
- Hard boiled eggs
- Rubber bands
- Molds/shapes
For my molds, I glued some old plexi-glass together in a 90 degree angle.
They are about 3 inches long and 1 inch wide.
You don't need anything too fancy, just look around the kitchen and see what you could use. Any small container that would fit an egg snugly but not too tight will work. Be creative.
Step 2: Square Eggs
Place the hot egg in one of the pieces and add the other piece to form a square. Hold it together with rubber bands and put it in the refrigerator for about 30 min until the eggs cools and hardens.
When you remove the egg it should be nice and square.
Step 3: Heart Shaped Eggs
For a heart shaped egg I start by gently pressing the egg with my thumb into the corner of one piece. The egg will flatten a bit.
Next, place the second piece, corner down, on to the egg and press gently to make an impression.
Be gentle, too much pressure will break the egg.
I held it together with rubber bands. Do not double the rubber bands, it will be too much pressure.
Place the egg in the refrigerator for about 30 min and let the egg harden.
Step 4: Oblong/rectangle
For this shape, I flattened the egg a bit and pushed it into a popsicle mold. It was a tight fit so I sprayed it with some cooking spray.
