Introduction: Getting Started With ESP8266(LiLon NodeMCU V3) Complete Guide for IoT Startup With Example(as Server)
Step 1: Installing the Firmware
In NodeMCU Boards the first thing you need is to install the Firmware to the board
the following method works for all NodeMCU Boards
- Open the NodeMCU flasher master folder than open the win32/win64 folder as your computer. now open the folder Release than double click ESP8266Flasher.
- Select the COM Port.
- Goto config tab
- click on the small gear and open up the firmware which you have downloaded
- go to the advenced tab and select the desired Baudrate
- Goto the Operation tab and click on Flash Button.
Step 2: Preparing the Arduino IDE
After Installing the firmware you are ready to do the programming with the ESP8266
- Install the Arduino IDE
- open the Arduino IDE from the desktop icon
- Click on File tab and than open preferences
- In the additional Boards Manager URLs add the following link (http://arduino.esp8266.com/stable/package_esp8266com_index.json) and click OK
- Goto Tools>Borads>Boards Manager
- In the search field type esp8266 click the esp8266 by ESP8266 Community option and click Install
Step 3: Code...
Now you can do whatever you want with your NodeMCU board
Following is an example for led blinking with NodeMCU board via webserver
- In arduino IDE goto tools>Boards>select NODEMCU 1.0 (ESP - 12E Module)
- again goto tools and select port.
- Change the Wifi name and password from the following code.
- Now click on Upload button to upload the following code.
- Connect the led's positive leg on D9 pin of board and negative to the ground of the code.
- Power up the board and open the serial monitor from arduino IDE
- after connecting to the wifi it will show you the IP address.
- type that IP address on the web browser(Edge, Chrome, Firefox etc..)
- A webpage will open you can change the status of LED by turning it ON or OFF.
#include<ESP8266WiFi> const char* ssid = "Tenda"; //your WiFi Name const char* password = "12345678"; //Your Wifi Password int ledPin = 03; WiFiServer server(80); void setup() { Serial.begin(115200); delay(10); pinMode(ledPin, OUTPUT); digitalWrite(ledPin, LOW); Serial.println(); Serial.println(); Serial.print("Connecting to "); Serial.println(ssid); WiFi.begin(ssid, password); while (WiFi.status() != WL_CONNECTED) { delay(500); Serial.print("."); } Serial.println(""); Serial.println("WiFi connected"); server.begin(); Serial.println("Server started"); Serial.print("Use this URL to connect: "); Serial.print("http://"); Serial.print(WiFi.localIP()); Serial.println("/"); } void loop() { WiFiClient client = server.available(); if (!client) { return; } Serial.println("new client"); while(!client.available()){ delay(1); } String request = client.readStringUntil('\r'); Serial.println(request); client.flush(); int value = LOW; if (request.indexOf("/LED=ON") != -1) { digitalWrite(ledPin, HIGH); value = HIGH; } if (request.indexOf("/LED=OFF") != -1) { digitalWrite(ledPin, LOW); value = LOW; } client.println("HTTP/1.1 200 OK"); client.println("Content-Type: text/html"); client.println(""); client.println(""); client.println(""); client.print("Led is : "); if(value == HIGH) { client.print("On"); } else { client.print("Off"); } client.println(""); client.println(" On "); client.println(" Off "); client.println(" "); delay(1); Serial.println("Client disonnected"); Serial.println(""); } //code copied from link
If you encounter any problem comment it down
