Introduction: Harry Potter Bookend
Hello! This is my first post here on the site. I tried to make the bookend to my book shelf with Harry Potter theme and I would like to share the results with you. I used materials that you can find easily and at a low cost. If you like or have any suggestions, please be free to leave your opinion. I hope you enjoy!
Ps: I shot a video of the whole process, I hope to share the link soon!
_______
Olá! Este é o meu primeiro tutorial aqui no site. Eu tentei fazer um aparador de livro para a minha estante no tema Harry Potter e gostaria de compartilhar os resultados com você! Utilizei materiais que você pode encontrar facilmente e bem baratinhos também. Se você gostou ou tem alguma sugestão, por favor, não esqueça de deixar a sua opinião. Espero que você goste!
Obs: Eu filmei todo o processo, quando eu terminar de editar, compartilharei o link do video!
Step 1:
- 2 Pieces of wood of the same size
- Black Cold Porcelain
- Toy Train
- Ink
- Hot Glue
- Styrofoam
- Paper Card
- Wood Glue
- Photographic Paper
_____________________
Materiais:
- 2 peças de madeira do mesmo tamanho
- Biscuit preto
- Brinquedo de trem
- Tintas
- Cola Quente
- Isopor
- Cola de madeira
- Papel Fotográfico
Step 2: Rails
In the first step we will make the basis of our platform. You should put the train in the wood and make a straight line on each side of the train. (Figure 1 -2) After this process, connect the two horizontal lines with small lines between them. The distance between the lower rows was about 0.5 cm. ( Figure 3-4 ).
With the mass of cold porcelain, do little lines like a worm, try to do it with the same size and with the same number of horizontal lines that we did earlier with the pencil. Then do a larger line with cold porcelain, this time, to form the thickest part of the trail. (Figure 7-9 ) Put these two parts on rail design that you made earlier and press for them to connect. ( Figure 10 ) For a better way, you can press with a ruler the side rail for a straighter shape. ( Figure 11 ) .Now, you should paint the part where the tracks will be with the help of black ink. You can choose any place to put the rails but do not forget to leave a piece reserved. Let dry.( Figure 12-14)
_________________
No primeiro passo iremos fazer a base da nossa plataforma. Você deve colocar o trem no meio da madeira e fazer uma linha reta em cada lado do trem. ( Figura 1 -2 ) Após este processo, ligue as duas linhas horizontais com pequenas linhas entre elas. A distância que eu utilizei entre as linhas menores foi de mais ou menos 0,5 cm.( Figura 3-4)
Com o biscuit, faça pequenas formas como uma minhoca, tente fazer de tamanho igual e com o mesmo número de linhas horizontais que fizemos anteriormente com o lápis. Depois faça uma forma ainda maior, dessa vez, para formar a parte mais grossa do trilho ( figura 7-9 ). Coloque os dois no desenho de trilho que fiz anteriormente e pressione levemente para eles se conectarem ( figura 10 ) Para uma melhor forma, você pode pressionar com uma régua a lateral do trilho para uma forma mais reta. ( Figura 11 ). Agora você deve pintar a parte onde os trilhos ficarão com a tinta preta. Você pode escolher qualquer lugar onde os trilhos devem ficar, mas não esqueça de deixar um pedaço reservado. Deixe secar. ( Figura 12-14)
Step 3: The Portal
With a pencil, you must make the shape of a portal ( figure 1-2) . Just as we did before, we will do a line with the cold porcelain around the drawing. With a knife, make small risks in the mass for a better effect ( figure 3-7 ) Then paint the portal with the black ink and around him, with brown paint.( figure 8-10)
The Styrofoam plate must be cut into small squares, it is not necessary that they are the same size as being different, the effect becomes more interesting ( figure 11 ). Glue the squares with the help of hot glue. Then paint them with brown ink or a color of your preference. Let dry and paint again for a better effect. ( figure 14-21)
__________
Com um lápis, você deve fazer o formato de um portal. ( figura 1-2 ) Assim como fizemos anteriormente, faremos uma linha com a massa de porcelana fria ao redor do desenho. Com uma faca ou estilete, faça pequenos riscos na massa de biscuit para um melhor efeito ( figura 3-7 ) . Depois, pinte dentro desse portal com a tinta preta e ao redor dele, com a tinta marrom. ( figura 8-10 )
A placa de isopor deve ser cortada em pequenos quadrados, não é necessário que eles sejam do mesmo tamanho pois sendo diferente, o efeito fica mais interessante ( figura 11 ) . Cole os quadrados com o auxílio da cola quente. (figura 12-13 ) Depois, pinte-os com a tinta marrom ou uma cor de sua preferência. Deixe secar e pinte novamente para um melhor efeito. ( figura 14- 21 )
Step 4: Hogwarts Express
In the toy train, I made minor modifications to seem a little more with the Hogwarts Express. I used black, red and gold paint. (Figure 1-4). For the windows, paint them with a gold paint and using a detail brush, make small shadows of people as in the figures. If you fail, you can use a cotton swab with gold paint and repair. (Figure 5- 12) This part requires a lot of patience, take a deep breath and you can do it.
_______
No trem de brinquedo, fiz pequenas modificações para parecer um pouco mais com o expresso de hogwarts utilizando tinta preta, vermelha e dourada. ( figura 1-4) . Para as janelas, pinte-as com uma tinta dourada e com um pincel de detalhes, faça pequenas sombras de pessoas como nas figuras. Se errar, você pode utilizar um cotonete com a tinta dourada e consertar. ( figura 5- 12) Nesta parte é fundamental muita paciência, então, respira fundo que você consegue.
Step 5: Putting It Together
For this step, pass the wood glue on the base of the wood that we use for the portal. Push for wood connect well to the other. If possible, place a weight on top while the glue dries.
____
Para esse passo, passe a cola de madeira na base da madeira que utilizamos no portal. Pressione bem a madeira para ela se fixar bem à outra. Se possível, coloque um peso no topo enquanto a cola seca.
Step 6: Details
- The Hat: With a small amount of cold porcelain make a ball. With your fingertips, press the tip of the base until it be similar to Figure 2, a form of hat. Model the tip to reach the expected result. ( figure 1-3)
- The Cage ( figure 4-8 ); In this step, use the cardboard. 6 rectangles cut with the scissors, as in Figure 4, one with a larger width. In the larger rectangle, stick with the aid of white glue the cardboard ranks. Now, join the two ends of the base with white glue also, if necessary, you can cut the length of the rectangle of rows. Connect the loose parts, always putting different ends, it is necessary to apply pressure to stick more easily.
- Suitcase ( figure 9-10): Although the previous step, remaining few square styrofoam and I found it interesting to use them to the bag. Paint a styrofoam square with black ink and make two thin lines of Styrofoam, paint them with gold. Stick the pieces with hot glue.
- Platform 9 3/4 ( figure 11-12): Print on photographic paper (the effect is more beautiful), a photo of plataform 9 3/4 plate ( I used this link: http://4.bp.blogspot.com/-fVbRdaz9EAU/U8F1pTxCLKI/AAAAAAAAC9o/DmmkajfohqU/s1600/Platform-sign.png) Stick with hot glue on the styrofoam and paint the edges of black ink or a color of your choice.
_____________
- Chapéu: Com uma pequena quantidade de biscuit, faça uma bola. Com as pontas dos dedos, aperte na ponta da base até a mesma ficar parecida com a figura 2, uma forma de chapéu. Modele a ponta até chegar ao resultado esperado. ( figura 1-3 )
- Gaiola ( figura 4-8): Neste passo, utilize o papel cartão. Corte 6 retângulos com a tesoura, sendo um mais grosso e os outros 5 mais finos. No maior retângulo, cole com o auxílio da cola branca as 5 fileiras de papel cartão. Agora, junte as duas extremidades da base com a cola branca também, se houver necessidade, você pode cortar o comprimento das fileiras de retângulo. Conecte os as partes soltas, sempre colocando de extremidades diferentes, é necessário fazer pressão para colar com mais facilidade.
- Mala ( figura 9-10). Ainda do passo anterior, restaram alguns quadrados do isopor e achei interessante utilizá-los para a mala. Pinte um quadrado de isopor com a tinta preta e faça duas tiras finas de isopor também, pinte-as de dourado. Coloque as peças com cola quente.
- Placa: Plataforma 9 3/4 ( figura 11-12) : Imprima em uma folha de papel fotográfico ( o efeito fica mais bonito ), a foto da placa da plataforma 9 3/4, utilizei o link ao lado. ( http://4.bp.blogspot.com/-fVbRdaz9EAU/U8F1pTxCLKI/... ) Cole com a cola quente no isopor e pinte as extremidades de tinta preta ou de uma cor de sua preferencia.
Step 7: 9 3/4 Platform
With a few more square Styrofoam complete the entire shelf region, where it will be the floor. Stick with hot glue and paint the squares with black ink. ( figure 1-2)
[OPTIONAL] When dry, use a varnish over the cold porcelain for the material last longer. ( figure 3-4)
__________________
Com mais alguns quadrados de isopor, preencha toda a região da plataforma , onde será o piso. Grude com cola quente e pinte os quadrados com a tinta preta. ( figura 1-2)
[OPCIONAL ]Quando seco, utilize um verniz por cima da porcelana fria para o material durar mais. ( figura 3-4)
Step 8: Final Details
Stick to the details with the help of hot glue the way you like. Make the last case still finish of a failure in the paint and its done! I hope you enjoyed
______
Grude os detalhes com o auxílio da cola quente da forma que mais gostar. Faça o último acabamento caso ainda haja alguma falha na pintura e está pronto! Espero que tenham gostado!
