Introduction: How to Make a 12v Battery Charger
About: Hi, I'm Steve! I'm a creative mind with a knack for technical skills—I can build just about anything you can dream up! From innovative projects to captivating designs, I bring ideas to life with passion and pr…
Hey! everyone My name is Steve .
Today i'm going to show you How to Make 12v Battery Charge
With this charge you can charge any type of 12 v battery even your car battery
it is very necessary in cold days because battery drains out very quickly .
This Charger features 2 step Charging 1. Constant Current 2. Constant Voltage
it is very safe and stable for daily use "it's very standard "
Click Here to See The Video
Click here to see the new video
Let's Start
Step 1: Stuff I Used
  • Dc to Dc Step Down Converter - click
  • Alligator Clip - click
  • Multi-meter - click
  • Laptop charger
  • it's will convert 19 volts from your charger to 14 volts to charge the battery
  • it'll provide constant voltage and constant current. ( very necessary )
  • it comes with 3 indicators led (red, blue and green) red show constant current blue show load and green show constant voltage "full charge"
Features
  • Input voltage range:6-38 VDC (Note: input voltage not exceeding 38V)
  • Output voltage range:1.25-36VDC adjustable
  • Output current: 0-5A
  • Output power: 75W
  • High efficiency up to 96%
  • Built in thermal shutdown function
  • Built in current limit function
  • Built in output short protection function
Step 2: Prepare the Adapter
Follow the Steps
  1. Cut down the jack of the adapter
  2. Remove the outer shield with a blade (Carefully)
  3. you'll see 2 wire red and black , black is negative and red is positive (see the image)
Step 3: Connection
You can see the label over the board
  • The red wire of adapter will go to "IN+" positive of the board (see the image)
  • The black wire of adapter will go to "IN-" negative of the board
  • tight the screw terminal with a screw driver
Now connect alligator clip
  • Red alligator clip wire will go to "OUT+" Positive of the Board (see the image)
  • Black alligator clip wire will go to "OUT-" Negative of the Board
Step 4: Configuration
Now you need a multi-meter to set it up
  • Plug the power to the adapter
  • Connect the black alligator clip to negative lead of multi-meter and red alligator clip to positive lead
  • you can see 2 Potentiometer over the board (see the image)
  • first one is voltage and second one is current
  • Now select the DC voltage reading on your multi-meter and turn the Potentiometer with a screw driver until you get 14 volts reading on multi-meter
  • Now select the Current Reading on your multi-meter and turn the second Potentiometer with a screw driver until you get 2 amps reading on multi-meter (you can go up to 5 amps all it depend upon the battery capacity if you have a bigger battery "like a car battery you can go up to 5 amps "
Step 5: You Are Good to Go
Just plug the red alligator clip to positive of the battery and black alligator clip to negative of the battery
and plug the power to the adapter
You'll see blue led will glow there it means it is charging If you see green led glows after some time it means the battery is fully charged
If You see Red led with Blue led that means it is in constant current charging
Enjoy
Thank you for visiting my Instructables
Stay tuned for next Projects
