Introduction: How to Dice an Onion
In this "ible" I will attempt to show you how I dice an onion, although a small onion is used the steps are the same for a large onion, you just make more horizontal slices
Step 1: Peel and Halve
Hopefully you know or can figure out how to peel and halve an onion, thats the starting point
Step 2: First Real Cut
The first cut is horizontal into the body of the onion, if your dicing a larger onion you can make 2-3 or even 4 horizontal slices. Cut back to the root but don't cut the root
Step 3: Splitting Cuts
Next you make longitudinal cuts into the globe of the onion, the number really depends on the size of the onion
Step 4: Dice
slice across the longitdinal cuts to make your finished dice
Step 5: In Response to Comments
In response to comments about the horizontal cut being unnecessary, I went and tried it out, after all, it's possible I've been doing it wrong all these years..... I found that although the inner layers did fall apart nicely without the cut, the outter layers would need more knife work to be closer in size. Although I used a rather small onion the results were obvious
