Introduction: How to Make a Wooden Dog Bowl From Pallet Wood!
About: I am a woodcarver/woodworker from the UK. I make all sorts of things for clients and for fun, but I also create inspiring and "how to" videos, write blogs, articles and step by step guides. Please search for m…
This dog bowl was created from old pallet wood and hand carved with decorative leaves and my dogs name.
A very simple build.
Simple butt boards together and glue them up. You need them to be longer and wider than the bowls you will insert later.
Next cut 2 holes in this piece, the right size for your bowls. I did this by drilling a hole through the board, then cutting out a circle using a jigsaw.
Lastly I cut 2 thin strips of wood and glued them straight to the top panel. These will act as legs and give a front and back panel to decorate how you wish!
That's it! If your bowl needs to be larger or your dog is quite boisterous with its feeding, then I may suggest some extra support for the front and back panels. But this is more than strong enough for my little pooch!
Check out my video for how I made it! If the video isn't working please watch it at youtube here.. http://youtu.be/qcQgZ9JM6tQ
