Introduction: How to Make Some Cool Batch Files
I am new to Instrucatbles. This is my first Instructable. It is about batch coding. I hope you guys like it.
Step 1: Matrix
1:
Open a New Text Document on Notepad.
2:
copy the code below into it:
@echo off
color 0A
title Matrix
:loop
echo 11000011010010100100110101001010100101010101
echo 00111100101101011011001010110101011010101010
goto loop
3:
go to "File" and click "Save As..."
When the box pops up, type in Matrix.bat (the .bat part is important)
Save it anywhere.
Explanation:
echo off: if you typed "echo hi" the user would only see "hi" not "Echo hi" and on the next line "hi"
color: changes the color
title: changes the title
:loop is a line of code that you can skip too.
echo ____: anything typed after "echo" will be shown in the console window.
goto ___ : goes to the line of code specified
Step 2: Shutdown and Calculator
Shutdown:
1:
Open a New Text File in Notepad
(There are very many Variations of this code, but my favorite and most trollish is
shutdown /f /p
2:
Type in
shutdown
3:
You should get a screen with lots of stuff on it. scroll up.
Type in any combination of /_'s or -_'s that you are able to do.
4:
When the box pops up, type in Shutdown.bat (the .bat part is important)
Save it anywhere.
Calculator:
1:
Open a New Text Document in Notepad.
2:
Type in:
echo off
:start
cls
set /p math=Equation?
echo Is this your equation? %math%
pause
cls
set /a RESULT=%math%
echo Your answer is: %RESULT%
pause
goto start
4:
When the box pops up, type in Calcuator.bat (the .bat part is important)
Save it anywhere.
Explanation:
cls: clears the screen.
set /p ___= : sets player input. Anything after the equals sign (=) is showed in the console window.
set /a ____=__ : Used to set an arithmetic value. set /a result=%math% would mean the result is saved as variable %result% and the variable %math% (which the user set) is the math that the computer does.
pause: Halts all code running until the user presses a button. Displays message "Press any button to continue..."
Step 3: If/If Not Statments
These are kind of complicated.
Example:
echo off
echo 1) Exit
echo 2) test
set /p begin
if %begin% == 1 exit
if %begin% == 2 goto test
:test
echo It Worked!
pause
exit
Here, if the user set input equals 1, exit.
if the user set input equals 2, it goes to the line ":test".
This can open up to awesome new things, like quiz games and guessing games.
In that example, the user would set the variable %begin% to either 1 or 2.
As for if not, it can open up to guessing games and password programs.
Example:
echo off
echo Hello! type 5-2.
set /p uu
if %uu% == 5-2 goto yay
if not %uu% == 5-2 goto nay
:yay
echo Your answer is: 3
echo Thanks for listening.
pause
exit
:nay
echo YOU DID IT WRONG!
echo HOW DARE YOU NOT LISTEN TO ME!
pause
exit
Here, if you type 5-2, you go to line :yay.
if you type anything else, (if not) you go to line :nay.
Explanation:
If not: If anything else is entered as variable %__%, do the following
if: if _ is entered as variable %__%, do the following
Step 4: Creating (and Adding To) Files
This one is easy to remember.
Example:
echo off
cls
echo Hello!
echo Hello! I bet you didn't see this file coming, did you? > haha.txt
pause
exit
This can open up to cool things like organizing assignments, to-do lists, and a whole lot more.
One cool thing I came up with will come up within the download with everything else at the end.
the way this works, is, in the example, the text "Hello! I bet you didn't see this file coming, did you?" will be copied into file haha.txt in the same folder as this .bat file.
The one > means, if i opened this, and it saved the file, and i changed what it puts into the file saved it file again, it would ONLY say the new words. If you put >> it does not overwrite like that.
Step 5: The End, and Downloading!
Thank you for reading all the way to the end! i hoped this helped those who were looking for cool batch files and those wanting to learn batch coding alike. And i will be making more like this if some people like this.
Download:
