Introduction: JUMBO PAPER MACHE EGGS
This is a wonderful project for three awesome reasons…
1. It is great to do with kids.
2. You don’t need a whole lot of supplies and what you do need doesn’t cost much.
3. The finished project is so fun to decorate with!
So gather your kiddos, gather your supplies and get ready to make some awesome jumbo paper mache eggs!
Step 1:
Large balloons
Glue (for 5 jumbo eggs we went through 5 small bottles of Elmer’s glue)
Newspapers
Paint
OPTIONAL-glitter, why not? :)
paper trimmer- saves a lot of cutting time
Newspapers
Paint
Step 2:
Cut lots of strips of newspapers 1-2″ wide. You can see how the paper trimmer works great for this project! We cut 1-2 pages at a time that were folded and then just opened them up and tore in half.
Step 3:
Blow up your balloons. I actually like the eggs better when we didn’t blow them up to their full potential because as you will see with the yellow striped egg, it kind of lost it’s egg shape:)
Mix one bottle of glue with 1/3 cup warm water. Then dip each strip in the glue and rub any excess glue on the side of your bowl.
Bowls work great to hold the balloons while you apply paper mache.
Just a note…my daughter preferred to rub the balloon with glue and then lay a dry newspaper strip on the wet glue and then rubbed glue on the newspaper.
So whatever fits your fancy. Just start covering your balloons with one layer of glue and newspapers.
Step 4:
Try to keep newspaper strips as smooth as possible.
We let each layer dry over night.
Step 5:
Be sure to be silly and have fun as you go:)
Oh, and when kids aren’t looking you might want to try to smooth them out a little more:)
Step 6:
We applied 3 coats of paper mache letting each coat dry overnight.
Now to decorate!!!
FYI… We used foam and regular brushes to apply craft paint to our jumbo paper mache eggs, however, you could use spray paint. I pulled out my Kilz spray paint primer but it was too cold in the garage to spray the eggs. It worked out fine without the primer, however, if you are looking for perfect eggs :) you won’t want to miss this step because you can see the newspaper print through two layers of the yellow and orange eggs.
Now to decorate!!!
Step 7:
Reece didn’t waste any time deciding how to decorate his first egg- Detroit Lions colors:)
Step 8:
Reece decided on silver pokadots on his bright blue egg so we found a clean sponge and traced a circle on it. I used my Keurig filter :) It was just the right size.
Step 9:
We put some silver paint on a small disposable container lid with a lip. Reece dabbed the sponge in the paint, lightly scraped the excess off on the side, and then gently but firmly applied the dot to the egg:)
Step 10:
We let the dots dry about 15 minutes before flipping it over to complete.
Step 11:
Once all the eggs were painted and completely dry, I decided to add some water base varnish to make them a little bit shinier.
Step 12:
We also striped and speckled and glittered some of the eggs. The options are unlimited:) Just visit http://joyfuldaisy.com/jumbo-paper-mache-eggs/ to see more. HAPPY CRAFTING & HAPPY EASTER:)
