Introduction: Jittery Servo Repair
I have dozens of servo motors operating in a project called "Santa's Shop," and one servo joint developed the "jitters" or "shakes." I replaced the offending motor and that restored the operation to normal.
Now that it is summer, I decided to examine the jittery motor and see if I could restore it (as a spare) and I found an easy cure for the shakes.
Step 1:
Remove the four screws that hold the motor shell together.
Step 2:
You are trying to get to the feedback pot, which is usually located beneath the circuit board.
Step 3:
With the board lifted (on my servo), you can see the pot.
Step 4:
Remove the screw that secures the pot.
Step 5:
Locate the tabs that secure the back of the pot.
Step 6:
Using a small screwdriver, bend the tabs so that the back of the pot can be released.
Step 7:
This looked a little worn and dirty, so I cleaned it with a readily available safe cleaning wipe (toilet paper--good for cleaning black stuff). Yes, I wiped it with plain old toilet paper (two ply) for about ten seconds.
I reversed the process and put the servo back together--now it works like new :)
