Introduction: K'NEX Supercar Instructions
This instruction set shows how to build a K'NEX Supercar model. I improvised this model myself with all the pieces that I had. I used the 3D CAD software SketchUp to create the 3D renderings.
You can download SketchUp for free (SketchUp Make 2017) at https://help.sketchup.com/en/downloading-older-versions
Step 1: Steering Module
The following set of instructions show the revolutionary steering system I developed. I discovered the basic principle design back when I was 13 lol. The construction is simpler than it looks. Just follow them through carefully. Good luck and enjoy :).
Step 2: Main Body Module
This is the central part of the model, which will contain the steering wheel and seats, as well as providing the necessary structural support for the front and back wheel modules.
Step 3: Steering Wheel, Dash Board, and Seats
The next step is to build the interior components such as the dashboard, steering wheel, and inclinable seats.
Step 4: Back Wheel Module
This module might be a little tricky to build, so I will do my best to illustrate the construction.
Step 5: Front Cover Module
This is probably the hardest stage to follow, because pieces are going to be bending at all sorts of angles and there are about 14 connection that you have to make to fit it to the main body. However this is the part that strengthens the entire front of the model together as well as gives it that dynamic look. Once you have completed this stage you can pretty much put the tires on and give it a test ride.
Step 6: Back Cover Module
The following stage will add the back cover including the fins. This will complete the chasis and framework. After this, you can put the tires on and give it a drive. However the tires are slightly modified so it is important that you look at the next step.
Step 7: Tires
Okay it is time to make the tires.
