Introduction: K'nex Marble Shooter!
A knex gun that can shoot marbles or chap-stick containers, possibly other objects, 5+ feet depending on the item. (YEs, it is weak. dont be harsh on me!)
Step 1: Parts FTW.
mk.
You need,
Rods: 9 yellow
Connectors: 1 White Snowflake,
1 Orange Straight 2 way,
4 Gray/ Purple 1 slot
Misc: 2-4 rubber bands,
Ammo. Use Chap stick tubes or marbles. Try others, and post what works please!
You need,
Rods: 9 yellow
Step 2: ASSEMBLE.
K, ill explain it as best as possible.
Take your snowflake connector, put the yellow rods in, sideways. Make 7 one way on it, 1 the other.on the single one that is backwards, clip the orange connector to the top near the rest of the rods. On the opposite end, snap on a gray/purple one, and again right above it.
Step 3: Last Part.
Take a yellow rod, slip it through the middle on the snowflake. clip a gray or purp. connector on the end with all the rods. Take another gray/purp. connector, and tie 2-4 rubber bands onto the hole of it. Look at the pic to see how. Then, clip that on to the side with 1 rod.
Step 4: Fire.
Pull back the purple connector with the bands on it, put in the ammo, let go, and there you have it!
