Introduction: LED Recessed Lighting Retrofit
How to modernize ancient technology in about an hour while improving safety and being "green" at the same time. This retrofit of a seventies-vintage "can light" cost approximately twenty-five dollars for the under-the-counter LED light kit, plug and related hardware. Energy savings? Consider the light output of better than a forty-watt bulb for about six watts--to say nothing of all the heat you WON'T be generating.
Step 1: Materials
One under-the-counter LED light kit (120 VAC)
One lamp socket outlet adapter
One standard replacement plug
One tube clear silicone sealant (or equivalent)
One 6" PVC wall guard (behind-the
Step 2: Tools
One 3" hole saw
One drill
One pair wire strippers
One screwdriver w/multiple bits
One pair side-cutters
One drill
Step 3: Assembly
Turn off power to recessed (can) light
Remove dome and bezel from old recessed (can) light
Remove bulb from can light; replace with socket outlet adaptor
Remove dome from bezel; take care not to damage bezel or dome retaining clips
Find center of wall guard using compass/protractor; check for accuracy
Cut 3" hole (may differ from light kit to light kit) using hole saw
Place new PVC adapter inside old dome bezel; press old retaining clips down onto PVC adapter
Using clear silicone, liberally seal around inside edge of bezel, and outside/inside edge of PVC adapter (neatness counts)
Place light kit inside hole of PVC adapter and press down into sealant; wait until silicone has cured (!)
Using supplied power cord of light kit, make up a shorter power cable using standard plug replacement
Plug modular end of power cable into light kit; plug standard plug into socket outlet adapter
Re-Install entire assembly in old can light as shown
Restore power
Voila! You're done.
Restore power
Voila! You're done.
