Introduction: Led Powered Monster Energy Can
So i made a led lighted monster energy can, and this is my first instructable so I'm not too sure if this is very good but, this shouldent be very difficult to built, it took me about one hour maybe to do this.
-For this project you need dremel tool for cutting and grinding, you can use pliers also for cutting,
-something about 10x 8 plexi glass
-Can of monster
-3 or 4 leds
-12 volt power supply( depends on how many leds do you use)
-Hot air blower( I dont know the real term of this tool)
-Hot glue
I'm sorry if my english is bad :D
-Can of monster
-3 or 4 leds
-Hot glue
Step 1: Cutting Off the Monster Logo Out of the Can
Use dremel tool for cutting it of and grind it so there is no ''bad spots''
I'm sorry for not having a better picture of this.
Step 2: Cutting the Plexi and Making It to Half Round
so now cut the plexi with dremel or what ever you want use.
Make it a half round with hot air gun.
Picture below
Picture below
Step 3: Grinding Plexi
Use 400 or 800 sandpaper to make it smooth
Step 4: Grinding the Leds
Use same sandpaper to smooth leds surface
Step 5: Glue Plexi Inside the Can
Cut off the top of the can and glue the plexi inside
Step 6: Drill Holes for Leds
Now drill 5mm or 3mm hole for leds and glue them in
Step 7: Soldering Wires
Solder wires from leds to power suplly or battery or whatever you want to use. I'm sorry but for this i dont have a tutorial
After that it shoull be ready. Thanks for viewing this project!
