Introduction: Lego Safe
2/13/2012. This will show you how to make a Lego Safe in less than 10 minutes. The main reason for this is decoration, and I wouldn't use this as a actual safe to keep money in. The skill for this project is beginner...all you need is some Lego's!
Hint: If the images don't show up when you click on them and you are using Firefox then disable adblock and they should work!
Step 1: Materials
This is exactly what you need (the image) to make this...there are a LOT of 2 by 4's so
you actually need 37 2 by 4's!!!
So just look at the image and yeah...
Step 2: The Mechanism
This is probably the hardest part yet...you have to make the mechanism. Follow the pictures and look at the notes on them to get this right! It's not that hard, you just need to do exactly as I show you.
Step 3: The Frame and the Door
Now that you made your mechanism you need to cover it up...follow the pictures and read the notes!
Step 4: Finish
And here you are!
Please rate! It was tough to make this...not only the idea, but the problems,image sizes and editing.
Thank you for checking this out!!!
