Introduction: Lego Gun
I've been looking around instructables for lego guns, and a lot of them require hard to obtain pieces, so I made a really simple Lego gun (not automatic) that fires rubber bands over 40 feet!
This is my first instructable, so please help me improve my creation!
Step 1: The Handle
The Handle is extremely important. In one of the pictures below, you can see that thereis an indent. That indent is 2 spaces deep, one space wide, and two spaces high. A space is the little bumps on the tops of bricks. The indent is so that the trigger can be pulled back far so that the rubber band can slide off.
Indent dimesnions - 2 spaces deep, one space wide, two spaces high
Handle Dimensions -4 spaces deep, three wide, five spaces high (with a 1/3 brick on both ends to keep it together.
Step 2: The Trigger
Okay for the trigger you need two 16 x 1 bricks with the holes in them (See the white brick in the picture) and two 140 degree joint peices (the beige ones). Then, you put a rubber band around the little peg (the ball thing) and around the trigger (to counter-act the pull of the ammo rubber band). After that, its pretty straightforward.
Step 3: The "claw"
Basically the gun is a rubber-band shooter. So, to hold the rubber band in place at the tip, you use one of those little claw peices to hold it.
Step 4: Hope You Liked This Instructable!
Some extra notes-
1. Always use a stronger rubber band on the trigger than the one you are shooting.
2. Stronger rubber-bands means more power.
3. Please do not hurt anyone with this instructable. It was meant for recreational puroposes.
