Introduction: Little Bits Car
http://youtu.be/FmlDLx3cZt0
Step 1: Gather Materials
MAterial list:
5x birch wood planks 30.48cmx30.48cm
3x Little bits power source
2x Little bits motor
2x little bits LED lights
1x Little bits
4x Little bits wires
1x Little bits double wire
1x wireless transmitter
1x Little bits wire receiver
1x Little bits cloud
1x Little bits fork
2x Little bits switch
2x Lego wheels 56mmx26mm
2x Lego wheels 22mmx13.2mm
12x zip-ties
1x marker
1x ruler
1x drill
Step 2: Laser Cut Wood
Laser cut the car floor, sides, roof,and rear and the front, sides, and roof of the hood using the dimensions from the pictures. Dimensions are inches
Step 3: Assemble Switch
Attach one of your little bits power sources to the split wire. Then attach to switches to each end of the split wire. Finish by attaching the switches to a wireless transmitter.
http://youtu.be/ytSN30ydFM0
Step 4: Assemble Little Bits
First attach a little bits power source to a little bits fork. Then attach two wires to the fork and attach the wires the two motors. Add your last power source to the cloud. Then attach the cloud to the wireless reciever and connect the two LED lights to it via wires. Then drill holes in the car floor so you can use zip ties to tie down the little bits with the LED lights near the front and motors in the back.
Step 5: Finish Project
Attach the 56mm wheels to the motors in the back and attach the axle near the front of the car where you will and the 22mm wheels. Then attach the car sides, rear, roof, and hood to the car wiith holes drilled in the front of the car for the lights.
