Introduction: Love Knot Bangle Bracelets
About: Hi, guys!! I’m Daisy. I love putting beads together to make jewelry work; sharing jewelry designs. If you like jewelry and beads, you are in the right place. I’ll regularly update new jewelry tutorials about b…
Valentine’s Day themed tutorial again! DIY love knot bangle bracelets with aluminum wire~
Step 1: Supplies
1.5mm Aluminum Wire
Round Beads Container (assistive)
Round Nose Pliers
Wire Cutter Pliers
Side Cutting Pliers
Step 2:
Cut a length of purple aluminum wire to approximately 23~25cm. Find the center location and tie an overhand knot there. Tighten the wire knot slightly with fingers and pliers.
Step 3:
Take a same length of pink aluminum wire. Pass half of it through the purple knot. Bend the right half of pink wire to create a loop in clockwise direction. Take the left half of pink wire and pass through the loop downwards.
Step 4:
Tighten the knot slightly in same way and this is the complete love knot.
Step 5:
Flatten and shape the wire around the round beads container.
Step 6:
Wrap the ending 3cm pink (or purple) wire around the purple (or pink) one.
Step 7:
Make a loop and a hook at two ends respectively.
Step 8:
Try another color combination for your beloved one.
Step 9: Congratulations!
