Introduction: Make a Net With the Handmade Tool
I am going to show you how to make a net and also a tool for making it.
All you need:
-a knife
-a saw blade
-a thread or a rope
-an ice cream stick or a piece of wood
-a flat piece of plastic or wood
-anything that can be used as a hook (a nail, a piece of wire etc)
Step 1:
Step 2: Material for the Needle
For the needle you will need a piece of wood (ice cream stick in this case), a small sharp knife and a saw blade.
Step 3: Make a Needle
On one end (left) of he stick cut out about 5 mm from the middle as in the picture. (for the bigger stick you can cut out 10-20 mm).Using the knife, sharpen the other end and make a hole about 15 mm from the pointed end. Now cut out the wood about 15-20 mm from the pointed end, leaving a needle-like piece of wood in the middle. Widen the hole with the saw blade.
Step 4: Define the Size of Meshes
Define the size of meshes with a little plate. The size of the mesh depends directly of the width of the plate. You can use a piece of plastic or wood.
Step 5: Roll the Thread on the Needle
I am using bigger needle (also handmade) and a thicker rope so it can be seen better. Start rolling like in the picture.
Step 6: The Thread Is Rolled
Now you can start making the net.
Step 7:
Roll the thread over the plate twice and tide a knot.
Step 8:
Hang the obtained mesh on a hook.
Step 9:
Place the knot on the middle of the plate.
Step 10:
Pull the needle through the mesh.
Step 11:
Pull the thread tight, but make sure that it goes around the plate.
Step 12:
Now you have 3 threads between the hook and the plate. Pull the needle under 2 threads on the right side, leaving 1 on the left. Make sure that the thread fixed to the needle goes over your left hand (if you are right handed).
Step 13:
Pull the thread and you will obtain a knot.
Step 14:
Now you have 2 meshes.
Step 15:
Repeat these steps until you get the desired width of the net.
Step 16:
The net is getting wider and wider.
Step 17:
Put all the meshes in the upper row (one by one) on the hook. (In the step 15 I hold these meshes with my left middle finger, right index finger and right thumb).
Step 18:
Now you can make the net lengthwise.
Step 19:
Now repeat the steps from 9 to 13 to make the second row (to get the net longer) And add the rows until you obtain the desired dimensions of the net.
Step 20: The Finished Net
You can use a net like this to make various objects (for keeping fish, for example). Be creative.
Step 21: Another Net (from Ordinary Rope)
