Introduction: Make Arduino Uno Work Like Leonardo
First of all i want to make this clear it is not like any other turn your uno into a HID only device with one time sketch uploard, you can upload sketches side by side with hid
THAT'S RIGHT! you read what you read no downsides to anything upload sketches like you do on an leonardo without reflashing 16u2 firmware HOW's that for a shock?
SOOOOOOOOOOOOOOOOOO without further talk lets get HIDDING (pun intended).
It also works on arduino mega
Update : Vote for me if you like it. it is in the tech contest and the mcu contest vote for whichever you think it is applicable for or both :D
Step 1: The Tech Talk: Skip If You Dont Care
hello welcome to the tech talk, here i explain everything techy.
SO lets go
The arduino uno the worlds best proto dev board with an ever expanding community but every piece of gold is rough somewhere. That is it dose not have usb HID(human interface device) capability thats where your project dies with a revival potion called the arduino leonardo the leonardo based on a usb capable chip can be used as a usb device a mouse, keyboard whatever but most of us are lazy enough not to buy an arduino leo and search for other ways one of them is to make a arduino leo but that ain't possible for some of us as the chip the leo is based on, is SMD only so no DIP(through hole)package but the uno also uses the chip's little brother the atmega16u2 for programming and that's what we will play with using the DFU mode
So continue to the next step for the knowledge that everyone needs ->
Step 2: The Main Knowledge
This is the general info of what we are going to do
We are going to change the firmware on the usb to serial converter of the uno to work also as a HID simulator
You can still flash chips like normal and also make a usb mouse, keyboard etc.
This your home grown arduino leonardo - no downsides
Continue further to download the stuff you need
Step 3: What You Need
ill keep this short
you need to download the file included it contains the HID library and the hoodloader bootloader
Step 4: The Main Step
Now you start by installing FLIP while your arduino is plugged in
next go into FLIP and select device as atmega16u2
now look closely if you have an arduino uno r3 then do as shown in the picture with the jumper for a second or two with your arduino plugged in for other arduino versions look on google for arduino (version) dfu
Tip : go to device manager and look in com ports before shorting the two pins your arduino should be listed after shorting the pins for a second the arduino should be detected but not listed
now in flip click on the usb cable and and select the option 'usb' (CTRL+U)
it should detect your device and now click on file and load hex file -> locate to the hoodloader folder and select hoodloaderX_X.hex now click on 'run' (not 'start application' it looks promising but is not the option) it should burn the flash on the chip to check unplug the arduino and replug it in device manager you should see hoodloader beta or something similar update the driver for that- select browse my computer for device software and browse to the hoodloader folder it should prompt a security warning(or not)just accept and install
Now go to the final step
Step 5: FINAL Step
now install the HID library you downloaded
to do that you copy the folder HID-master remove the hyphen by renaming it and place it in the arduino/libraries folder now open the arduino ide go to sketchbook > libraries > HID and upload any example its same as the original usb library for the leonardo so you can copy paste some things
here's an example download the .ino file
connect an analog joystick x axis (horizontal) to A1
connect analog joystick y axis(vertixcal) to A2
upload and replug your arduino you should have a hid mouse in device manager
AND for other tech related stuff check out my blog at : techspacey.blogspot.com
