Introduction: Making a Bluetooth Adapter Pt.3 (Headphone-Jack)
In this instructable, I will be showing you how to utilize my Bluetooth Adapter to make an old speaker Bluetooth compatible.
*If you have not read my first instructable on "Making a Bluetooth Adapter" I suggest you do so before continuing. Click Here to access my first Instructable.
The materials you will need are:
Wire connectors -- Click Here
3.5mm Headphone-Jack Adapter -- Click Here
Wire Strippers / Cutter
Electrical Tape
Soldering Gun / Material
Step 1: Start
You will need a 3.5mm Headphone-Jack Adapter.
I used these wire connectors from Amazon. Click Here
Step 2: Headphone Adapter (a)
For this step, you will need to cut the ends of the wire off.
(Shown Above)
I used wire cutters for this step.
Step 3: Headphone Adapter (b)
Next, you need to strip the wires for both of the ends of the headphone adapter.
For this step, I used wire strippers.
Step 4: Headphone Adapter (c)
For this step, you will need some connectors I used when I made when a Bluetooth Adapter (specifically the ones I used in my Bluetooth Adapter).
I used these connectors from Amazon -- Click Here
Step 5: Headphone Adapter (d)
Next, you need to strip just the male end of the connectors.
Step 6: Headphone Adapter (e)
Next, you need to solder the male end of the connectors on to the Headphone Adapter.
I used a soldering gun and soldering material for this step.
Step 7: Finishing
Congratulations, you have now finished making the 3.5mm Headphone-Jack adapter for my Bluetooth adapter.
Once you are done, I recommend you wrap the naked wires in electrical tape to protect them.
You can find my instructable on how to make a Bluetooth Adapter compatible with this adapter here.
